HELP!! Puking coolant - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 12-28-2013, 11:15 PM Thread Starter
Sxr212's Avatar
Well I just got back from a trip and when I got out I noticed coolant all down the side of the truck and on the ground. Checked the overflow and it was empty and the cap seems to be stripped? I Did some research and I've been seeing that it could be a blown head gasket? How would I check that or what other symptoms would there be? What is the difficulty of fixing this? Any help would be greatly appreciated!! Thanks
Sent from AutoGuide.com App
Sxr212 is offline
post #2 of 14 Old 12-28-2013, 11:45 PM Thread Starter
Sxr212's Avatar
Just checked the oil and it isn't milky colored at all
Sxr212 is offline
post #3 of 14 Old 12-29-2013, 12:00 AM
john galt's Avatar
Quoted: 1095 Post(s)
if your cap is stripped that could be it right there. get a new stant cap and if you are lucky it is a five dollar fix.
I havent experienced it personally but I did find my truck puking from a pin hole that developed in the overflow tank. a stripped cap would do the same thing and i have heard of the stock cap wearing out.
if not, maybe this will get those with more experience to chime in
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #4 of 14 Old 12-29-2013, 12:02 AM Thread Starter
Sxr212's Avatar
I really hope so but before I left I had filled it up and it wasn't stripped and now it is but we'll see
Sxr212 is offline
post #5 of 14 Old 12-29-2013, 12:07 AM
john galt's Avatar
another thing, the original fill line on the overflow is wrong it should be just below the low line or that can cause it to puke. ford later corrected this blunder with a sticker.
I would get the stant cap as you will want the upgrade anyways and fill it to just below the low line and watch it. also I would really check out my oil and coolant for signs of contamination but...i digress
post #6 of 14 Old 12-29-2013, 12:10 AM
john galt's Avatar
again there are a lot of folks on here who have forgotten more about these trucks than I shall ever know so
also I just realized I assumed you had a 6.0.
post #7 of 14 Old 12-29-2013, 03:56 PM
PSDTV21's Avatar
Why because it was puking coolant? : Sorry just kidding, couldn't help myself.
Anyway, I would start looking around the block to see if there is anything coming out from there. I would also check the hoses as well
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #8 of 14 Old 01-02-2014, 01:25 PM Thread Starter
Sxr212's Avatar
Haha no it's 95 but I just replaced the cap and I'll be pulling the same grade tomorrow so we'll see what happens. And I'll check around the block for leaks too.
Sxr212 is offline
post #9 of 14 Old 01-03-2014, 12:28 PM
john galt's Avatar
yup...thats why
probably that and i just fixed a similar problem on my truck, tracing it to a pin hole in my coolant reservoir
post #10 of 14 Old 01-03-2014, 02:09 PM
john galt's Avatar
still interested to see if changing your cap helps. I have never wrenched on a 7.3 but i think the cooling system design is similar as far as the reservoir fills the radiator and if your cap is leaking it would not build pressure right or that stands to reason for me anyways.
IF you have a half decent mechanic in your area you should be able to get your system pressure tested easily and cheaply enough.
