ICP and fuel line broken - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-28-2013, 08:20 AM Thread Starter
So I finally get "the pig" back on the road in what seemed to be problem after problem and poof major fuel leak on my way home from work. 1/4 of a tank leak, fuel line split in two and in the process of removing I broke the top half of the ICP. Not to big of deal other than the fuel line is a made to order or dealer item and the icp is right at 200 bucks....I was to the icp is the same as the ebp but I'm not seein it that way. Am I wrong and any sources for icp for way less than 200 bucks????
Az SON is offline
post #2 of 2 Old 12-30-2013, 08:22 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
AutoNation Ford White Bear Lake (previously Tousley Ford) has them for about $129 (list is $200). Cheers!
Patrick Feeley is offline
