glow plug issue. ideas? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 12-23-2013, 10:18 AM Thread Starter
the baconator
terryknight's Avatar
Quoted: 144 Post(s)
well i went to replace the GPs in the 97. got down the the rear most one on the drivers side and had an issue. the GP has come apart (so far 3 pieces) the top came off with the fuel line, i unscrewed the main body, and the inner part seems to be stuck in the head. i can see it and get pliers to it (not vice grips they are too big). the piece i see moves around when you touch it. i tried pulling it out with the pliers no luck, i removed the diode for the IDM and cranked it over seeing if compression would push it out, no luck. I am trying to not remove the head. any ideas?
I think my next option is to try and pull at teh same time someone cranks the motor over, then remove the injector/rockers/pushrods and see if i can get a better grip. then i guess if everything fails see if i can drive the GP into the cylinder and fish it out, then finally option is the pull the head.
i will add pictures when i go back and take the camera
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #2 of 21 Old 12-23-2013, 10:27 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 45 Post(s)
Nightmare come to life. Good luck bud...
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 21 Old 12-23-2013, 10:49 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
I've seen the old boy at the shop deal with that a couple time terry. He strips what he needs to in order to get a set of needle nose vide grips on it then hooks a slide hammer to the vise grips. It's a slowwwwwwwwwwwww process. Couple gentle taps out with the slide hammer, tap it back down. Couple taps out, tap it back down....repeat repeat repeat repeat repeat. He worked on the last one for like three hours working it back and forth till it's almost free the spins the engine over and blasts it and any shrapnel out in one good blast of compression.
The end of the glow plug swells sometimes and they get stuck. It happens to every brand name.
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #4 of 21 Old 12-23-2013, 10:53 AM
Interior Guru
weareweird69's Avatar
Quoted: 102 Post(s)
Feedback Score: 3 reviews
What JJ said.
But do not knock it into the cylinder. Because you'll never fish it out.
-Garrett
Too many projects. Too little time...
weareweird69 is offline
post #5 of 21 Old 12-23-2013, 11:37 AM
Matthew82's Avatar
Oh wow that sucks Terry. I have no idea how to get that out but JJ's plan sounds good to me
Originally Posted by fordmandan87 View Post
Matt are you on the sauce?
All 3 at the same time? Who do you think you are, Charlie Sheen
Matt the odds of you convincing the guy he's not in possession of a kryptonite vagina that commands top dollar for the hour is lower than me getting to bang a millionaire midget on mars during a meteor storm
Matthew82 is offline
post #6 of 21 Old 12-23-2013, 11:54 AM Thread Starter
the baconator
Quoted: 144 Post(s)
didn't think of the slide hammer. i have pulled the injector forgot to drain the oil/fuel i did manage to bend the top over
and you're right these were motorcraft plugs
i was thinking if i raise the piston to TDC, then knock it into the cylinder it can't go far but it will now be "loose"
and if i can't fish it out i am really no further behind than when i started
post #7 of 21 Old 12-23-2013, 12:06 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Should have installed a fuse......
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #8 of 21 Old 12-23-2013, 12:09 PM Thread Starter
the baconator
Quoted: 144 Post(s)
yeah damn.... next time i'll know better
post #9 of 21 Old 12-23-2013, 12:36 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
That's why the needle nose vies grips terry. Once you get them clamped on, leave them on. Just tap on the handle of the vies grips with a hammer when tapping it back down. The idea is just keep wiggling it back and forth back and forth. At first the movement will likely be imperceptible.
-JJ-
JJFLASH is offline
post #10 of 21 Old 12-23-2013, 02:47 PM Thread Starter
the baconator
Quoted: 144 Post(s)
the one problem with that is where the GP is #8 PITA the firewall is in the way however i will get on it probably thurs. borrowed a borescope from a buddy to look at it from inside the cylinder. have thought about welding the two parts together and unscrewing it. think that will work or think it will break the weld? I guess i need to figure out what metals the two parts are. may wind up leaving it for the time being we'll see. will the GPs work if one is unplugged?
