Water pump gasket - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-20-2013, 05:08 PM Thread Starter
Water pump gasket
I've had a pinhole leak in my water pump gasket that I need to fix. Should I replace the pump? i've seen them for $75.00 on e-bay. Are they just junk? Anyone use one? Thanks
8my$ is offline
post #2 of 6 Old 12-31-2013, 08:23 AM
Quoted: 91 Post(s)
Surprised no one responded. I broke a bolt in my water pump when replacing my t-stat. I replaced the whole pump and found it was about to go out anyways. Replace it, use a fine grit sand paper to clean the surface and DO NOT use any rtv. Torque the bolts (can't remember the specs) and call it good.
White95f250 is offline
post #3 of 6 Old 12-31-2013, 08:58 AM Thread Starter
Thanks for the info. Still havn't strarted the project. Any tricks to get the gasket to stay during install?
8my$ is offline
post #4 of 6 Old 12-31-2013, 09:28 AM
jesilvas's Avatar
Quoted: 3 Post(s)
I DID use RTV. I'm good.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 6 Old 12-31-2013, 10:05 AM
Quoted: 91 Post(s)
I should correct myself by saying I used small dabs of RTV to hold the gasket in but do not use it as a sealer. You could get away with it but it's not designed for it.
post #6 of 6 Old 12-31-2013, 10:27 AM Thread Starter
I'm going to replace it soon. It's a small leak, but I don't think it will fix it self. Thanks for the help.
8my$ is offline
