96 won't start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-17-2013, 05:27 AM Thread Starter
96 won't start
Went elk hunting Thanksgiving Day returned a week later and truck would not start. No WTS lamp, replaced flow plug relay and nothing. No white smoke so I assumed fuel pump and replaced. Nothing, tach bounces while cranking so I ruled out CPS, or should I still replace? Wants to start off ether but never lights off. Again no white smoke while cranking...am I missing something simple or could it be HPOP? WTS lamp still does not come on either. Frustration has set in a week ago
Az SON is offline
post #2 of 5 Old 12-17-2013, 06:22 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Have you checked your fuses? specifically fuse 22 in the engine bay? if its not that read this Diagnosing a 7.3 no start
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 5 Old 12-17-2013, 06:02 PM Thread Starter
Glo plug relay $100. Fuel pump $175. Two weeks of aggravation. $5 dollar fuse problem solved....thanks for your help Rammstein 1224
Az SON is offline
post #4 of 5 Old 12-17-2013, 06:05 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
if it blew once, itll blow again...think about replacing your fuel bowl heater....
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #5 of 5 Old 12-18-2013, 05:13 AM
Chapter Director
Quoted: 5 Post(s)
Yes sir that or unplug it, as long as you dont live in like Antarctica its really not needed
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
