96 f350 cold start question. - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 25 Old 12-17-2013, 03:07 AM Thread Starter
96f350powerstroke's Avatar
Not sure if this is a problem but figured I would post here in case it is. Again I am new to owning a diesel. It's finally gotten "cold" here in Florida, whopping 40*. The last two mornings when I start my truck it wouldn't fire up after first glow plug cycle. I had to cycle the glow plugs again and it fired right up no problem. Once started it purred like a kitten no lagging or loud "clacking". I've search the forums and some say this could be a sign of injectors going bad? Or is this normal? Thanks for any help and advice!
96 f350 powerstroke
6 position tuner
3" down pipe 4" turbo back
Newly built tranny, billet tourque converter, heavy duty clutches, shift kit
Stock motor with 189k
9" lift on 37" toyo M/t's
96f350powerstroke is offline
post #2 of 25 Old 12-18-2013, 05:06 PM
i would test your glow plug relay first then maybe glow plugs. look it up on youtube, there are some videos that show you how. if you want to know if your o-rings are getting bad an easy way is to check your fuel filter and see if its black. that'd be oil if it is and caused by injector o-rings getting worn. but i would start with the relay. also a very easy test. make sure your meter u test with is on DC voltage.
troylj is offline
post #3 of 25 Old 12-19-2013, 04:48 AM Thread Starter
I read that also. I haven't had time to check anything yet because of work schedule. I get a couple days off next week so will look into it then. This morning was the coldest it's been all year, took 3 cycles to get her started. I hear what I believe is the GPR click when I turn the key forward.?., so I'm assuming its working. I will check it out next week to be sure. Has anyone who knows their rig is 100% that has to cycle the glow plugs more than once to get it to fire? Just wondering, if assuming everything is functioning properly, if at colder temps with no block heater is multiple cycles of the GP normal? Thanks again
96 f350 powerstroke
6 position tuner
post #4 of 25 Old 12-19-2013, 05:52 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Theres definitely something up with it. 40 is nothing for a diesel, its not until you start getting to teens and single digit temps where it starts to not like you. I would start with your GP system. A florida truck has never really had its GP system really tested so you never really notice that its going out until you get a "cold" day. Read this it will tell you how to test Troubleshooting GPR & GP's
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 25 Old 12-19-2013, 05:56 AM
mine started first try this morning. its 15 degrees and it wasnt plugged in. i got new batteries and glow plugs. you can hear gpr click even when its getting weak. best way to know for sure is to meter it. my money is on glow plugs or gpr or combination of both. both testable, easily replaced, and fairly inexpensive. its a good sarting point
troylj is offline
post #6 of 25 Old 12-19-2013, 05:58 AM
wow rammstein beautiful trucks
troylj is offline
post #7 of 25 Old 12-19-2013, 06:56 AM Thread Starter
First off I agree!! Second thanks for the info. I know 40 isn't cold which is why I thought there may be an issue. Thanks for the link, ill be runnin tests Monday. Ill update when I find the problem. Thanks again!
96 f350 powerstroke
6 position tuner
post #8 of 25 Old 12-19-2013, 07:02 AM
Chapter Director
Quoted: 5 Post(s)
Thanks guys I like the CCLB OBS you have. Ill trade you OBSs
But yea at 40 it should have absolutely no problems starting, hell thats t-shirt weather here
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 25 Old 12-19-2013, 07:31 AM
Quoted: 54 Post(s)
If you're "cycling" the glow plugs by turning the key off when the WTS light goes off, and turning it back on again, that's a complete waste of time, and just more wear-and-tear on the relay. The glow plugs stay on considerably longer than the WTS light, up to two minutes. Just leave the key in RUN for an extra 10-15 seconds. But indeed, if it actually requres that extra GP run time to start, then you need to test the glow plugs, the relay AND the wiring from the relay to the UVCH connectors.
RedneckYankee likes this.
madpogue is offline
The Following 2 Users Say Thank You to madpogue For This Useful Post:
96f350powerstroke (12-19-2013), RedneckYankee (12-20-2013)
post #10 of 25 Old 12-19-2013, 07:38 AM
allergic to hot weather
95and05's Avatar
Send a message via AIM to 95and05 Send a message via MSN to 95and05
I would assume glow plugs ate an issue but also there has to be something els.
All of my trucks from 1992 - 2010 will start at 30* no problem without allowing glow plugs to cycle at all (not recommended). I am a little harder on my trucks occasionally as I am a firefighter and will sometimes just crank and roll.
Keith in Alaska (lovin it)
94 IDI
95 7.3 ex cab L/B 4X4 (D66 stage 1s 4" Turbo back 6637 air filter and bully dog chip)
05 6.0 Excursion 4X4 (stock)
10 6.4 F350SRW CCLB manual trans (stock)
95and05 is offline
