Clutch switch - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-16-2013, 05:10 PM Thread Starter
Clutch switch
Got a new to me truck and the cruise did not work. Did some investigating and found that the clutch switch was not there and the plug was cut and wired together. Went to the ford house got a pigtail and went to oreillys and got a switch. Got the switch wired in but when i put the switch in and pressed the clutch pedal the switch comes back with the rod. Making the computer think that the clutch is still pressed and not allowing the cruise to work. Did they redesign the switch becasue the new one i got has a little knob on the firewall side of it. My other truck does not. Any help would be great. Thanks
94.5 F350 CC LB 4X4 5 spd
AFE Stage 2
4" Exhaust
Turbo Upgrade
TS 6 Pos Chip
FPR Shim
Equailzer hose
3 gauge a pillar pod, Pyro, Boost, and soon to come Fuel Pressure
kevinwoo11 is offline
post #2 of 2 Old 12-16-2013, 11:02 PM
JSchuricht's Avatar
A pic would help. IIRC the older trucks pre 92ish had a different switch so check the part number. Your switch should clamp to the rod and have some springs that push it away from the pedal when your not pressing it.
JSchuricht is offline
