95 won't start - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-16-2013, 08:33 AM Thread Starter
95 won't start
So it's cold, but I have the truck plugged in and can feel the block heater working. Hit it with the starting fluid. Nothing, not even tring. The WTS light comes on, and the tack is moving when cranking so I don't think it's the CPS. Should I just replace it first? What next? Thanks
8my$ is offline
post #2 of 9 Old 12-16-2013, 09:29 AM Thread Starter
Replaced the CPS, no help. Don't know why it won't fire plugged in with fluid? Any ideas? Thanks
8my$ is offline
post #3 of 9 Old 12-16-2013, 11:34 AM Thread Starter
Cel dosn't come on when I turn the key. Checked fuses and changed relays. PCM?
8my$ is offline
post #4 of 9 Old 12-16-2013, 11:41 AM
95sorensonOBS's Avatar
How are your batteries, fully charged? Mine did the same thing, batteries tested good but would not start if they were low at all. I've read they won't start if volts drop bellow 10 volts. I replaces my alternator and batteries and have not had any other problems
95 powerstroke
Ts 6 pos chip
Rosewood stage 1 injectors
Afe intake
3"downpipe
4" straight pipe
95sorensonOBS is offline
post #5 of 9 Old 12-16-2013, 11:58 AM Thread Starter
The batteries are fully charged. Not sure why the CEL dosn't come on when I turn the key. Seems like a fuse from what I've read? Thanks
8my$ is offline
post #6 of 9 Old 12-16-2013, 12:15 PM Thread Starter
So I went back to the fuse box to check again. Fuses appear good,but I switched a few of them 8-9, 21-22. Turn key and short CEL. It started right up. Not sure how, but I'll take it.
8my$ is offline
post #7 of 9 Old 12-16-2013, 12:18 PM
Well good glad ya got her to start!
95 powerstroke
Ts 6 pos chip
Afe intake
3"downpipe
4" straight pipe
post #8 of 9 Old 01-06-2014, 08:53 AM
Axlesteel's Avatar
Garage
8my$ I just had the exact same problem as you. I also switched those fuses (8-9) and she fired right up.. thats odd but shes runnin.
Axlesteel is offline
post #9 of 9 Old 01-07-2014, 03:22 PM Thread Starter
Never hurts to get lucky sometimes. Still not sure how or why? Maybe a bad connection with the clips and fuse.
8my$ is offline
