96 f350 with a different glow plug relay - Ford Powerstroke Diesel Forum
post #1 of 27 Old 12-15-2013, 05:55 PM Thread Starter
wondering why my glow plug relay is different from all the other ones i see. mine has 2 terminals directly across from eachother and a 2 wire plug in on the side. i read that cali trucks had a different style glow plug relay but pretty sure mine is not one because it doesnt have the c on the end of the model number on the valve cover and also it was built in kentucky. wondering if i can use the normal 4 post relay and just do away with the plug-in part
troylj is offline
post #2 of 27 Old 12-15-2013, 06:18 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Any chance we can see a picture of the relay?
Trucks and parts............
kanuck15 is offline
post #3 of 27 Old 12-15-2013, 06:40 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
C on the end of the valve cover?
Mine has no C and it is a California emissions truck
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 27 Old 12-15-2013, 07:19 PM Thread Starter
not sure how to get a picture on here... and it should say A215C on passenger side valve cover across from year. i will work on getting a pic up
troylj is offline
post #5 of 27 Old 12-15-2013, 07:23 PM Thread Starter
troylj is offline
post #6 of 27 Old 12-15-2013, 07:24 PM
kanuck15's Avatar
Quoted: 10 Post(s)
Make a photobucket account
kanuck15 is offline
post #7 of 27 Old 12-15-2013, 07:32 PM
Patrick Feeley's Avatar
Quoted: 10 Post(s)
The early trucks (like my 94) used a relay that had the control wires plugged in with a weathrepack connector. I've never heard of a 96 having one, but I guess it's possible. Ford used to sell a kit that had the 4-post relay like you normally see and a pigtail that converted the weatherpack connector out to wires with ring terminals. You could get the 4-post relay (I would get the Western Plow or White-Rodgers) and just cut off the weatherpack connector and splice on some ring terminals. Cheers!
Patrick Feeley is offline
post #8 of 27 Old 12-15-2013, 07:43 PM Thread Starter
when i ordered parts in i bought a relay from xdp just to have around for when mine went out and never put 2 an 2 together until it actually came in and i looked at it. on the xdp website they dont even have a different option for glow plug relays from 94-03. so maybe i could use this one and just do away with the plug?
troylj is offline
The Following User Says Thank You to troylj For This Useful Post:
RedneckYankee (12-15-2013)
post #9 of 27 Old 12-16-2013, 03:56 AM
Quoted: 4 Post(s)
That is because the relay that patrick is talking about for the 94 is obsoleted. They have been replaced by the 95-03 ones. You would need to retrofit the 95-03 solenoid to fit the 94. NOT a big deal. But ALSO, like he said, it was a 94 thing, your 96 should not have it
post #10 of 27 Old 12-16-2013, 11:41 AM
XtremeDiesel's Avatar
PM on the way!
Powerstroke.org Members Save 10%!
for News, Contests & Giveaways!
Call us @ 1-888-DIESEL4
XtremeDiesel is offline
