Huge oil leak need help - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-15-2013, 12:15 PM Thread Starter
Angry Huge oil leak need help
On rly cold starts I have a oil leak that's on the driver side it runs Dow the front diff anyone out there got any ideas wear it can be comming from bc I ant find it and it's not just a little leak if it's +10 out its dumps like 2 qourts of oil on the ground help would be great 1995 ford f250 5speed
Redneck2221 is offline
post #2 of 11 Old 12-15-2013, 12:48 PM
Chop's Avatar
In English most of these guys and gals would think it's the oil cooler located underneath the exhaust manifold . The cold weather and the age of the seals tend to do this .
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #3 of 11 Old 12-15-2013, 02:20 PM Thread Starter
I kinda thought of it as that to the trucks got 306000 miles on it and I got it from the original owner and everything is original and it only dose it I the cold so it is prob that
post #4 of 11 Old 12-15-2013, 05:41 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
If it is leaking that bad, it should be simple to find
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 11 Old 12-15-2013, 07:10 PM
RedneckYankee's Avatar
Could be coming from gasket on oil filter. Mine ripped on me didn't realize it till the temp dropped down to the low 20's. It only did it for a short period of time then it stopped as soon as warm oil got into the filter weirdest darn thing. Had no oil coming from above were oil on front dif. was and no real amount of oil on filter drove me nuts looking for it.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #6 of 11 Old 12-16-2014, 11:33 AM
Hey redneck2221 did you find it?
Hey Chop there is an oil cooler under the Exahust manifold on the drivers side?
Hey Folks Those of yoyu that Watch... Sorry Redneck2221 I'm going to Hijack your thread because My Issue deals with the same Problem. When it's below 20 My truck pisses oil untill it warms up. I have narrowed it down to one of these two lines.. anyone know what they are and can these conections be replaced? See pic
Click on pic to see larger version
well got those lines wiped off and started the truck and nope not from the conections but above that up on the frame??? Crap
Edward
Rochester, Wa
1997 F350 Crew Cab 4x4
1965 Fairlane Wagon
1988 Suzuki Samurai Tin Top
Well Technically I still have!
1977 Toyota Hilux
1987 Samurai Soft top
1988 F350 Crew Cab 7.3 IDI Flatbed
2002 Jeep Liberty
2000 F150 4x4 Extended cab 4 door Short bed
edwardldog is offline
post #7 of 11 Old 12-16-2014, 01:46 PM
Chop's Avatar
Yep the drivers side it is ,use oem seals and gaskets .Your pics are of the fuel lines ,one for return and the other to pump .Those are wet from I suppose the oil cooler .Cooler is coupled with the oil filter head .
Chop is offline
post #8 of 11 Old 12-16-2014, 04:00 PM
Hummmm Ok you have my attention Fuel lines ? ok Now I have to get a better look...
Edward
Rochester, Wa
1965 Fairlane Wagon
1977 Toyota Hilux
2002 Jeep Liberty
post #9 of 11 Old 12-16-2014, 05:23 PM
fordsvtparts's Avatar
Quoted: 81 Post(s)
My best guess would be one of the O ring seals on the HPOP if it's coming from the top. Otherwise look at the oil cooler, just as Chop mentioned.
Otherwise it could be one of the high pressure lines or fittings. However those usually don't just stop leaking once they warm up.
The lines in the pic are just fuel lines; the only oil lines in the engine are the two coming from the HPOP.
We are Autonation Ford of White Bear Lake selling all OEM Ford parts at employee prices (formerly Tousley)
Call us at 1-800-328-9552 (be sure to mention this website when calling)
OR check out our website
Try out Ford's website as well!
I'll meet or or beat any price on OEM parts
fordsvtparts is offline
post #10 of 11 Old 12-17-2014, 11:09 AM
Quoted: 86 Post(s)
Its your oil cooler and most likely o rings. I just did mine and luckily the front housing gasket wasnt leaking so i got away with new o rings and rear oil filter housing gasket.
USE DEALER ONLY O-RINGS!!! Dont ask me how I know.
White95f250 is offline
