New t-stat and overheat - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-08-2013, 06:32 AM Thread Starter
LSSBoy's Avatar
I folks, since its cold here the temperature wasnt going up ( needle wasnt reaching the N on the gauge ). So I bought a motorcraft t-stat and had a little trouble. My t-stat housing was worn so coolant went all out by there. Changed the housing with a brand new motorcraft. I filled up the coolant everywhere I could, in the block ( where the t -stat sits ), unpluged the 2 heater hoses and fill em up. Fill the rad. Even do the air removal with a suction tool.
The problem now its the temp raise to past the L on gauge. Near the line before the red space. I do know that the t-stat IS opening because the hose upon it is damn hot ! The high of the rad too. Ive been looking at this since 3 weeks and cant find why ? Can someone help me
LSSBoy is offline
post #2 of 9 Old 12-28-2013, 10:23 PM
Is the thermostat installed correctly? 50/50 coolant water mix?
Freddyack is offline
post #3 of 9 Old 12-28-2013, 10:27 PM Thread Starter
LSSBoy's Avatar
Tstat correct yes. The mix im not sure.. but for now the gage is fuc ed up. Ill have to test it
LSSBoy is offline
post #4 of 9 Old 12-29-2013, 07:12 AM
ryandamo's Avatar
i would go to an auto parts store and get a mechanical temp gauge and see what the temp really is. The temp gauge on these trucks are idiot gauges, theres only 5 positions the needle can point to. it raises x amount of degrees it moves up one position, its raises another x degrees its moves another position, they dont work like a traditional gauge. You sender might be bad too. Or you could have go a bad thermostat from the factory
ryandamo is offline
post #5 of 9 Old 12-29-2013, 07:32 AM
Quoted: 80 Post(s)
Feedback Score: 4 reviews
Are you sure that you have the correct thermostat? There where two different lengths of thermostats offered dependent to what year your engine is. If you have a 96-97 engine and install a 94-95 thermostat the engine will overheat. Read here http://www.dieselsite.com/dieselsite203thermostat.aspx for a little more info.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #6 of 9 Old 12-29-2013, 08:30 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
I would bet your thermostat is in backwards
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #7 of 9 Old 12-29-2013, 09:04 AM Thread Starter
LSSBoy's Avatar
Thank you all for all the info ! Didnt knew for the lenght of tstat.. I have a 95 and pretty sur I have the good one. I ordered it from ford dealer and it fits very well. At first the gave me the wrong one ( the diameter was too small ).
Im sure it isnt backward because the upper hose of the rad is hot so coolant is going thru there. I have to check with mecanichal gauge.
Thank you ill give feedback when it will be done
LSSBoy is offline
post #8 of 9 Old 12-29-2013, 11:06 AM
Quoted: 80 Post(s)
Another thought would be if someone changed out the water pump and installed a 96-97 pump meaning your 95 thermostat would be the wrong one. Also what condition is the lower radiator hose, it could be sucking shut if in bad condition.
Jack
322000 miles
post #9 of 9 Old 12-29-2013, 12:19 PM Thread Starter
LSSBoy's Avatar
The hose is in good shape and have a spring in it. Everything seems fine. Im 90% sure when i will check it with a good thermometer it will be ok
LSSBoy is offline
