Broke bolts off in thermostat housing - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-07-2013, 09:33 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I am in the process of flushing my coolant and of course the bolts holding the thermostat housing were all rusted and 2 of 3 bolts broke off. As I was drilling out the left front bolt it cracked the whole corner off so theres little to no chance of getting it to hold a bolt. I'm assuming I'm screwed and will have to replace the water pump now?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 5 Old 12-10-2013, 04:45 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
That would be my suggestion (replace pump). Cheers!
Patrick Feeley is offline
post #3 of 5 Old 12-10-2013, 05:23 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Yea i ended up just drilling holes next to it so we will see how it holds up in the long run, seems to be holding for right now. If it doesnt work ill just replace the water pump
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 5 Old 12-11-2013, 11:14 AM
Quoted: 50 Post(s)
I would def. use the thermostat housing ring offered by Strictly Diesel to stabilize the joint between the housing and the water pump.
madpogue is offline
post #5 of 5 Old 12-11-2013, 11:30 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Interesting idea, havent seen that before, if i have troubles i may just make something similar to that just because i had to drill different holes
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
