96 jerking little throttle - Ford Powerstroke Diesel Forum
post #1 of 19 Old 11-30-2013, 12:25 PM Thread Starter
hey guys just bought my 96 about 6 months ago and have a shutter/ slight jerk under light throttle. It only does it in OD with light throttle or going up hill in lower rpm. If the truck downshifts it pulls hard but in od it will jerk a little feels like its not making good hp but still pulls. The truck does a ts chip and it seems to be working fine does the same thing in stock mode.
Truck has fresh oil change/ all filters, replaced injector harness pigtails had two burnt plugs which i though were my issue. I have a AE scanner and truck passes all test. though some of my injectors seem not as strong as the others. Not sure What is going on and any help would be great. Truck has good power but doesn't build boost at cruising speeds say 60 mph i have maybe 1 pound.
73nancy is offline
post #2 of 19 Old 12-15-2013, 06:15 PM
That Other Guy's Avatar
Quoted: 4 Post(s)
Running into same issue but havnt done any scanning, I am attributing it to a fuel issue cause as OP stated only in OD low RPMs light throttle. If I roll harder it will clear and go on or if it downshifts same thing just go on like nothing. I am guessing pump may be going as with low RPM(no pump speed compared to higher RPM) and hard load pump isn't putting out what it should for the load.
Am I thinking of this correctly? I am going to check pressure at Schrader valve tomorrow shouldnty it be 60 PSI for a good pump?
Also forgot to mention, new oil/filter, new fuel filter, FPR screen clean as a whistle, no fuel leaks, stock tuning, new Glow plugs(so not shorting anything out), new UVCH both sides, oil level good, new CPS. This has only recently started happening within the last few hundred miles.
97 toredor red metallic f350 XLT CCLB ZF5 7.3 4wd
HPO X-over, riff raff up pipes, 1.00 housing, WWII, 3" dp, 4" exhaust, Tymar intake, riff raff boots, 6.0 fan, tow pig in progress
15 white wrangler jku auto 4" MOPAR lift, fox remote res shocks, fox dampner, recentered H1s, 37" MT/Rs, bumpers, sun shades, hand grips, floor mats, blah ,blah.
02 TJ Wrangler 4.0 5spd
4" rubicon express lift, poison spyder rock rails, 17s on 35s, bumpers, blah, blah, blah.
00 Dutchman classic 30' 5er
GN attachment in pin box, new roof compliments of wood rot due to leaks, updating interior, a work in progress.
That Other Guy is offline
post #3 of 19 Old 12-17-2013, 01:35 PM
Quoted: 4 Post(s)
Wow out of this entire forum and 130+ views and all the people who own OBS 7.3s no one has had or heard of the issue that the OP and I are having?
post #4 of 19 Old 12-24-2013, 12:37 PM
Quoted: 4 Post(s)
Ok so since there are still no responses to this thread ill post up what I have been reading about my fuel pump.
I am suspecting its my pump for the reason it only does it at low rpm and light throttle so its just not putting out a lot cause no demand and its a mechanical pump. I have read that its still good if you have 45 psi at the Schrader valve on the fuel bowl but that its best to see it hang at 65 psi while at idle and so on.
I understand that its normal for the gauge to jump around a lot as its mechanical and only pumps every time the cam eccentric hits it but mine jumped from below 40 to above 60 never once gave me a steady number and this was at idle. Is my pump ok cause what im thinking or I guess wanting to think is that its going bad being as the low side of the reading was below 40.
post #5 of 19 Old 12-25-2013, 08:59 AM
gabegoforth's Avatar
Sounds more like the regulator for the jumpy pressure. Mine is smooth.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #6 of 19 Old 12-25-2013, 03:36 PM
Quoted: 4 Post(s)
I was thinking that even with the fuel pump only hitting when the eccentric hits that it shouldn't matter and the regulator should keep a steady pressure as you say, am I thinking correctly in that or is it not the case since soon as there is pressure its used by the running engine.
Anyway is there a way to test my regulator on the truck or is it just something I gotta throw a part at cause I don't feel like doing that.
Also would this cause the low rpm low demand surge, it gets real bad if I just let it happen so I either give more throttle or let out cause im slowing in town or whatever reason I don't need to keep going.
Either way its not a huge issue cause it doesn't happen all the time but I can make it happen everytime at low rpm low demand if I so chose which id rather not but just makes me feel something is going south(especially since its gotta worse the past few hundred miles).
Its just an old farm truck but its my old farm truck I have no payment on and I like it that way but id rather not get stranded by ole trusty rusty when the wife or daughter or both are with me.
post #7 of 19 Old 12-25-2013, 03:39 PM
Can you make a video of it. Is this a Auto? Cause I'm almost thinking all Fords do this it's just something your not used to. If I had a video I would know. Txt or email or post it up.
post #8 of 19 Old 12-25-2013, 03:45 PM
Quoted: 4 Post(s)
I can get a vid if you like but you really wouldn't be able to hear or see it happening unless it was on the dash and you can tell when the camera rocks from it. I highly doubt that all fords do this cause I have driven many 7.3 trucks while in the AF for my job and NONE did this I have also driven 6.0 and 6.4s but they are a different animal when it comes to fueling.
This particular truck I bought from a guy I have known for years and have ridden in it before and it never did it nor did he ever complain of it, it didn't do it when I first got it back on the road either just recently started occurring. Yes its an auto its the truck in the sig but the trans had a fresh rebuild before it was parked(5 years in a field) but all wiring issues are fixed and run through the truck is dead reliable but just having this small issue.
post #9 of 19 Old 12-25-2013, 03:48 PM
Oh ok. I didn't know if you had driven a few 7.3s. Well the electronic throttle peddle can do stuff, cam sensor. A video would be nice.
post #10 of 19 Old 12-25-2013, 03:49 PM
I'm just thinking that the truck is lugging and your noticing it. Is it similar to a manual. Cause the autos in these trucks like to stay locked up.
