1995 7.3 cam position sensor help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-27-2013, 09:00 PM Thread Starter
Well tonight I was on my way home and my truck ( 1995 f250 7.3 auto) died on me. I have an edge CTS so I pulled codes and cam position sensor came up. Can someone please tell me where it is? How easy are they to install? And roughly how much they cost? Thanks
nwatson is offline
post #2 of 2 Old 11-28-2013, 03:43 AM
Happy Thanksgiving! The CPS is on the front of the engine, passenger side, up near the fan. Lay underneath and you can see it, has a cable running to it. One bolt holds it on. Remove the bolt, pop it out and replace with one from Ford or International, the rest are known to not work out of the box. It will be snug, there's a seal around it. Good luck.
1996 F-350 Crew, Long Bed
injun46 is offline
