Dies at idle, random shudder under throttle - Ford Powerstroke Diesel Forum
post #1 of 22 Old 11-26-2013, 02:42 PM Thread Starter
95 f250 started dying at idle, I need some help to fix it. I took a 3 hour drive last Friday with no issues, and drove it Saturday as well. when I got in the truck on Sunday, I started it and it ran for about 45 seconds and then shut off like I had turned the key off. Every time I'd stop at a red light it would shut off within 30 seconds, and driving down the road I would get a random shudder but otherwise runs okay Under throttle. I changed out the CPS and that did nothing to fix the issue. It is leaking fuel into the valley but it has had a leak for about a month now. I haven't had time to address the issue, as this is my business truck. Any guidance to get this truck going is appreciated. I need it running again Ricky tick.
Thedutyunfolded1 is offline
post #2 of 22 Old 11-27-2013, 09:22 AM Thread Starter
Anyone have any ideas?
post #3 of 22 Old 11-27-2013, 09:39 AM
Arcturus's Avatar
Check the fuel pressure at the schrader valve on the fuel bowl. at idle it should be around 50-60 psi. Be careful when removing the gauge, fuel will shoot out of it. Any tire gauge will work.
Got any smoke at idle or when cruising? You may need to have someone follow you for a bit to see if smoking while cruising.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #4 of 22 Old 11-27-2013, 09:48 AM Thread Starter
No smoke while running in the driveway..ill check the fuel pressure when I get home this evening. Would there be something to cause a sudden drop of fuel pressure at idle to make it just turn off? I've had weak fuel pumps that would make a vehicle idle rough before, but never just shut off like you turned the key off...and then fire right back up.
post #5 of 22 Old 11-27-2013, 09:52 AM
mad103's Avatar
You more than likely have a dying fuel pump. I just fixed my 05 and had the exact same symptoms. Save money and start there. Mine drove fine sometimes and sometimes just idled really rough, as if it were a heavily cammed gasser and it died on me three times while driving. One time it turned right back on and other two times I had to get towed and a few hours later it'd turn on like normal as if nothing happened. My guess is the dying pump would heat up or overwork and die and after cooling down it'd fire right up.
Good luck!
2005 Ford F-250 Black/Brown Lariat 4-door/shortbed
8" Fabtech Lift
20" Rims and 38" Tires
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #6 of 22 Old 11-27-2013, 09:55 AM Thread Starter
Oh great. Well ill check the pressure this evening and that should be an indication. How much is a fuel pump for these things? Its mounted on top of the motor correct?
post #7 of 22 Old 11-27-2013, 10:02 AM
mad103's Avatar
Mine was on the frame rail under the driver's side seat. Idk about yours but find out what the exact part number is and look for it on ebay. I got quoted $500 at my local dealership and found it on ebay for sale by a dealership in chicago for $240-$290, I don't remember exactly. I think it was called geiser ford. Install on mine was pretty easy I did it myself with basic tools and fuel disconnect tool.
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #8 of 22 Old 11-27-2013, 10:04 AM Thread Starter
I've got the tools to do it, I've just never messed with powerstrokes before. All of my previous diesels were cummins..but I've never had a fuel pump go bad on a diesel that I've owned before
post #9 of 22 Old 11-27-2013, 10:11 AM
mad103's Avatar
You are steps ahead of me. I've learned to work on my powerstroke with no previous experience in any diesels. Google geiser ford in roanoke il and ask them for a quote or model number and shop around. Again my local dealership charged almost $500 just for the part and I paid like $250 plus small s/h from geiser
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #10 of 22 Old 11-27-2013, 10:15 AM Thread Starter
Rockauto has them for my truck for as cheap as 68 bucks. Ill check the pressure and if its not 50-60 psi ill see if I can find a deal on a pump locally. I need this truck running asap.
