Problems with DIY Exh Brake/EBPV? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-24-2013, 11:06 PM Thread Starter
97HotShot's Avatar
Ok so I decided I wanted to try the DIY exhaust brake method before buying a $1,000 aftermarket unit.
I unplugged the connector from the compressor housing and cut it from the factory harness about 3-4" back from the plug. I ran the colored wire straight to a battery with an in line fuse, and I ran the black wire in the cab to a 2 speed style push pull switch. The valve will function with the switch in the on position and the truck idling, but when I'm going down the road and attempt to use it there is obviously no braking power what so ever. I've tried it unloaded and today with my 43' car trailer with a single Toyota SUV on it. At 2500 rpm's I'm getting no braking assistance.
My friend took me for a short ride in his 95 this afternoon, and even unloaded in his truck you can definitely feel when the valve closes and starts braking.
Any idea's or suggestions on what to do? Should I have ran the hot to the switch instead of the ground?
97 F350 CC DRW 5spd SBC clutch, Swamps tunes, 3" DP 4" straight, Irate stainless bellows, WW2, Amsoil 4510 CAI, Autometer Gauges, Amsoil fluids throughout.
To do list: Plumb SD IC, Full Force Stage 1's, and some different tunes!
97HotShot is offline
post #2 of 4 Old 11-30-2013, 06:43 AM
delta99's Avatar
You should get an aftermarket exhaust brake which is designed to not blow out your seals.
Anyways, if you want to activate your ebpv, run a hot wire to the switch. Run a wire from the other pole of the switch to the colored wire on the actuator. This will allow it to function normally, as well as on demand.
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #3 of 4 Old 11-30-2013, 06:54 AM
72Ford250's Avatar
You need a ground to the black with the purple strip here is a wiring diagram I did for mine i hooked. A. Little more complicated than what you are trying to do. DIY exhaust brake?
I do support powerstroke power
1997 250 7.3L D66 Rosewood stage II t500 HPOP crx racing intercooled Mrbp 3'' down pipe 3.5 straight diy intake (chip is at the head doctor at bdp getting tunes)
1972 250 6.4L(390 FE.(gasser)
My Dads
2007 250 6.0L (325 hp stock
72Ford250 is offline
post #4 of 4 Old 11-30-2013, 07:07 AM Thread Starter
97HotShot's Avatar
Well when so many people here say its works decently I would like to try it, before I spend $1,000 else where.
Apparently the seal is already blown though because a friend stopped by last night while I was putting on new brakes and he's more knowledgeable about these trucks than I am. The reason mine isn't working is the seals are already blown. I thought my pedestal O-rings were leaking and he corrected me that its the EBPV solenoid. So now to figure out if I can rebuild it/reseal it.
