Banjo Bolt Trick - Ford Powerstroke Diesel Forum
post #1 of 1 Old 11-20-2013, 10:07 AM Thread Starter
Banjo Bolt Trick
Hi,
Replaced the fuel pump. Its cumbersome to get that banjo bolt started. You need 4 little hands it seems.
I used a drill bit as leverage to hold the assembly together. Worked great.
Will see if it solves my bucking, stumbling problem on the highway.
countryroad is offline
