coolant temp gauge - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-09-2013, 05:57 PM Thread Starter
coolant temp gauge
I just bought a 95 F250 7.3Lthe coolant temp gauge is not working. Changed the coolant temp sensor and still nothing. Voltage at signal wire on sensor is 3.6 volts. Is this normal?
wam9797 is offline
post #2 of 3 Old 11-10-2013, 09:33 AM Thread Starter
229k miles on it all relays and fuses are good
wam9797 is offline
post #3 of 3 Old 11-10-2013, 10:07 PM
Quoted: 50 Post(s)
Stick a screwdriver or pin into the sensor connector and touch it to ground. The gauge should peg to the right. If it does, it's good and you've got a wiring problem (or you replaced the wrong sensor). If it does not, the gauge head is bad.
madpogue is offline
