help please! - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-08-2013, 01:36 PM Thread Starter
Camok10's Avatar
help please!
I just picked my truck up. its a 94 F-superduty. it had the DI turbo engine with the zf5 speed.
the P.O. claimed it had ran out of oil sputtered out and stalled. I picked it up yesterday primed the HPOP no luck firing it up. so me and my friend proceeded to do and injector buzz test all 8 buzzed. now on to the tricky part, the engine will fire off either, but will not stay running maybe will run for 5 sec tops. and it needs to sit for about 3-5 min between to get it to fire up again. with out either we checked hpo pressure it will build up to ~ 1200psi. it will start to catch billow white smoke and its done pressure drops to about 25psi. let it sit it we can do it again. dose this sound like an ipr to you guys?
Camok10 is offline
post #2 of 17 Old 11-10-2013, 07:18 PM
sputnik801's Avatar
Quoted: 3 Post(s)
the "ran out of oil" statement scares me.... WHY did it run out of oil? How about simple first? Is the fuel filter plugged?
sputnik801 is offline
post #3 of 17 Old 11-10-2013, 07:43 PM
Quoted: 780 Post(s)
1200 psi is normal that's what most are at running down the highway at 55-60. Have you checked out the GP system?
Corey@CNCFAB is offline
post #4 of 17 Old 11-10-2013, 07:51 PM
And by all means quit using ether unless you want to replace the heads now.
97 F350 7.3 super cab full bed dually
Autometer Sport Comp II boost and egt
TS 6pos tuner
Clutch clevis mod
Tymar intake
Stancor/White & Rogers GPR
Dyno test 221.5hp @ 187,000 mi. Before mods.
Other mods soon :
diamond back dp and 4in exh
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #5 of 17 Old 11-10-2013, 07:56 PM
Start with basics. Sounds like fuel starvation as stated above. Is the in tank pump delivering fuel to the filter? How much fuel in the tank. Some of our failures in the tank have a pickup tube fault that will not deliver fuel at about 1/4 tank or lower. Is the fuel fresh?
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #6 of 17 Old 11-10-2013, 08:33 PM Thread Starter
Camok10's Avatar
Fresh fuel, I put 5 gallons in the rear tank and switched from the front because I don't know what he had in it but it wasn't diesel smelled kinda like paint thinner or kerosene. It has fuel, the filter has been changed and screen cleaned. The bowl was drained and it re filled it self with the fresh diesel. The either was just used to see if it will fire. But what dose it do so bad to the heads?
He stated the oil pan leaked which is very common here in the rust belt from the pans rusting out.
My question though, is why would it drop the high pressure off and not build it back up unless it sits for a few min? I'm going to replace the ipr this weekend. I was going to rebuild it but I broke it removing the plug so I figure that's a good place to start.
Camok10 is offline
post #7 of 17 Old 11-10-2013, 08:36 PM
Quoted: 780 Post(s)
The pressure drops out because there is a timer. If it doesn't start within X seconds the IPR will dump all pressure.
Don't use ether, ever. Use WD40 or something like that.
post #8 of 17 Old 11-10-2013, 08:41 PM Thread Starter
Camok10's Avatar
Ok but it should re set that timer going to key off and back on correct?
And the either is it because the glow plugs will ignite it?
Camok10 is offline
post #9 of 17 Old 11-10-2013, 08:45 PM
Quoted: 780 Post(s)
Yes. Ether will pre-ignite causing severe rod damage. Spitting/sputtering white/blueish smoke at start up is typically GP related.
post #10 of 17 Old 11-10-2013, 08:49 PM Thread Starter
Camok10's Avatar
I'll replace them, probably have 20 or so new ones at the shop allready checked the relay, it's good and functioning.
Also the truck had a super chips programer in it, I removed it and placed it back to stock setting.
Camok10 is offline
