1995 7.3 Accelerator parts, official names? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-04-2013, 08:19 PM Thread Starter
nightofstars's Avatar
I was wondering if any of these 2 parts may have also been called the throttle position sensor? Ford is saying they cannot find the throttle position sensor part for my 1995 7.3, so I was wondering if it may be called something else, possibly is the throttle position sensor actually one of these 2 parts? If anyone has any information, it would help a lot & thank you.
1. idle validation switch (maintains idle speed)
2. accelerator pedal position sensor (operates in a manner similar to a throttle position sensor)
nightofstars is offline
post #2 of 4 Old 11-04-2013, 11:30 PM
JSchuricht's Avatar
You want #2. The idle validation switch is just a switch that's activated when the peddal is out. The position sensor detects the actual range of movement of the pedal.
JSchuricht is offline
post #3 of 4 Old 11-05-2013, 06:42 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
The TPS (Ford might call it the Accelerator Pedal Position Sensor) for the OBS trucks that is available in the aftermarket is the Dorman 699-200. If you want factory, you have to buy the entire pedal assembly (F6TZ-9F836-AA). Cheers!
Patrick Feeley is offline
post #4 of 4 Old 11-09-2013, 02:22 AM
Once again Patrick you da Man! To the Op you might wanna look in a local auto wreckers yard. Thinking new via stealership you'll be needing serious dough..
jrc
'97 Red F250 CC XLT ZF5 3:55s, Dana 60, SD springs all round, 'jectors, IC, 6.0 fan, TW files, VisionX lights and other stuff.
'96 White/Silver F250 SCSB 4X2 (all stock for now)... 4:10's E4OD.
jcart is offline
