95 IPR replacement - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-03-2013, 05:23 AM Thread Starter
PSD_rookie's Avatar
95 IPR replacement
Well after several days of tracing down problems I finally figured out that my IPR was going bad and decided to tackle this PITA task. I went to Ford and purchased a new IPR, well they only carried 1 part number for the valve assembly. Well, when I get home and look at it, I realize that it doesn't have the little plate at the end of it that the 95 models do. What I'm wondering is do I HAVE to have the one with this plate? Or is there a way to remove it from the old IPR and put it on the new one?
TOTALED - 95 F250 XLT ECLB 4x4
4" turbo back, DIY tymar, Boost/EGT/Trans temp Gauges, 35/12.5 tires, ZF-5 swap with solid driveshaft, Oh yea, and P-pumped 12 valve swap
97 F350 CCLB 4x4
PSD_rookie is offline
post #2 of 6 Old 11-03-2013, 06:11 AM Thread Starter
PSD_rookie's Avatar
Ok, so I just realized that the difference is the edge filter. So what I guess I need to know is whether or not it has to have the edge filter? Or if its better to not have it seeing as how ford took it off for the 96 and newer 7.3s. Need help ASAP please, its my daily and I need to get this up and running today.
97 F350 CCLB 4x4
post #3 of 6 Old 11-03-2013, 06:56 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
It should have the edge filter (if that's what your had on it originally). They moved the edge filter to be integral with the pump on later engines). Cheers!
Patrick Feeley is offline
post #4 of 6 Old 11-03-2013, 07:00 AM Thread Starter
PSD_rookie's Avatar
Do you know if I can simply remove the edge filter from the old valve and put it on the new one?
97 F350 CCLB 4x4
post #5 of 6 Old 11-04-2013, 05:44 PM
Quoted: 13 Post(s)
No, you cannot do that. Cheers!
post #6 of 6 Old 11-06-2013, 05:57 AM Thread Starter
PSD_rookie's Avatar
Thanks, ended up buying the O-ring kit since mine were blown out, gonna run that for a while and keep the new valve for when I change my HPOP.
97 F350 CCLB 4x4
