Buzz test - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-02-2013, 02:02 PM Thread Starter
aaklingler's Avatar
Buzz test
I just ran a buzz test with my mtg2500 on my 1995 f350 and it gave p127 codes for all 8 injectors, is there something wrong other then the injectors to cause this?
1996 F350 CC 4x4 auto 196k DIY intake
2002 Excursion 4x4 255k 160/80 66mm gtp38 intake and exhaust
aaklingler is offline
post #2 of 4 Old 11-02-2013, 02:32 PM Thread Starter
aaklingler's Avatar
I reran the buzz test and it passed, I ran the cyl contribution test and I got p0266, the only codes I am currently getting are p380 and p0478, the truck runs rough, any ideas?
post #3 of 4 Old 11-02-2013, 07:30 PM
I don't think I'll be much help, but did you run the contribution test with the engine fully warm and running? If not it can give you false results
'95 ECLB XLT 4x4, E4OD, K.P. D60, 4:10's, 221k, TW custom tunes, 1st Gen Lightning 40/20/40 seats, Wicked Wheel 2, Bar None Bellowed Up-pipes, 360* thrust bearing, Garret Deleted Pedestal + H.F. Outlet, 6.0 fan, CCV dump, Melling LPOP, HPX S.S. oil line, Stancor GPR, 203* T-Stat, MBRP 3" D.P. to 4" exhaust, Tymar Intake, IssproEV2 gauges, Aeroforce Interceptor, Adrian Steel Box, Lund Screen-Front, Donaldson Air & Oil Filters, 2nd Owner
AccordinToJordan is offline
post #4 of 4 Old 11-02-2013, 07:59 PM Thread Starter
aaklingler's Avatar
Yeah, I think so, at first when I tried it it said something about the oil temp sensor.
