Fuel Pump and Performance ???????? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-31-2013, 12:48 PM Thread Starter
What are the symptoms of a weak and leaky fuel pump?
Found mind to be leaking and last weekend pulling the 5th wheel, I hit a head wind traveling 60mph in 5th gear, at 1800-1900rpms. RPMs started to drop and I could not accelerate to compensate for the lack of speed, so I had to drop it down into 4th and could stay steady at 55mph with about 2300rpms showing on the gauge.
Going up a long, but not so steep grade, had to drop in down into 3rd gear at 2800rpms just to stay at 45 mph.
Each time, my EGR would climb to about 1150*
I bought the truck thinking that a diesel would have no problem pulling almost anything.
My 5th wheel loaded (no water) and the 4 of us in my truck should only be about 10,100 lbs.
I have a Power Hungry 6 position chip (was set on heavy tow)
3.5 Down pipe, no CAT into 4Ē exh.
DIY intake (6630, not sure if thatís right on the filter)
Manual trans, single mass fly and clutch with a 4.10 Rear end
2 wheel drive with standard E rated truck tires, no big meats.
Thatís pretty much all the mods Iv got
I do have a new pump and a Fuel Bowl reseal kit from Diesel O Rings, just wanting to know if I expecting to much from this 1995 F250 PSD
Will be bumbed if I am.
Rosco69 is offline
post #2 of 17 Old 11-03-2013, 08:03 AM Thread Starter
Well, I'm not getting any response from my question, so I'll put the new pump and seals in and see what it does.
Being new to diesels, I'll just have to work thought my questions logically myself and "solder on"
Rosco69 is offline
post #3 of 17 Old 11-06-2013, 05:08 AM
rockinthe4banger's Avatar
My OBS is set up pretty much the same as yours but no chip. My camper is a 34' 9800# dry weight then you put the wife's stuff and we are close to 10800#. I know I will not win any races but hitting a head wind doesn't slow me down. Also, I recently rebuild the fuel bowl, installed a new pump, and cleaned the regulator screen. It woke the truck up and I don't believe it increased hp. I would replace the fuel pump, clean the regulator screen, and rebuild the fuel bowl but I would check for another fowl issue. It doesn't sound like your getting enough to have to drop that many gears with all the add ons you have.
rockinthe4banger is offline
post #4 of 17 Old 11-06-2013, 05:13 AM
Gun Nut
Rodslinger's Avatar
Quoted: 134 Post(s)
No that was our fault - your post got caught in the automatic spam filter and didn't post. I corrected it and all is well now. Sorry for the inconvenience.
'05 F250, CC, FX4, 6.0 PSD
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Please support our troops!
Rodslinger is offline
post #5 of 17 Old 11-06-2013, 07:30 AM Thread Starter
Thanks for the explanation as to why (no one cared )
Thanks to Rockinthe4B. I will be installing the new pump and rebuilding the bowl this weekend.
Up to this point I’ve done everything I can think of, including cleaning the screen. I hoping it’s just an old leaking pump.
I will post as soon as I know any more, but if others have any IDs I open to suggestions
Rosco69 is offline
post #6 of 17 Old 11-06-2013, 10:02 AM
Try these low cost mods that may help, individually may have little impact but cumulatively (least for my trucks made a difference SOP).
Shim fuel pressure regulator to 65 psi at idle
Clean Fuel Pressure Regulator Screen
Do power peddle mod
For my just new to me White/Silver F250 with out a DP yet the above made a noticeable SOP different.
jrc
'97 Red F250 CC XLT ZF5 3:55s, Dana 60, SD springs all round, 'jectors, IC, 6.0 fan, TW files, VisionX lights and other stuff.
'96 White/Silver F250 SCSB 4X2 (all stock for now)... 4:10's E4OD.
jcart is offline
post #7 of 17 Old 11-06-2013, 11:01 AM
Do power peddle mod
jrc
What is the power peddle mod? This one is new to me.
post #8 of 17 Old 11-06-2013, 04:40 PM Thread Starter
Iv done all the above mod's but the "Power Peddle" mod???????
But this will still not fix my leak, or answer the ? could this leak cause lack luster power?
Rosco69 is offline
post #9 of 17 Old 11-07-2013, 06:16 AM
Gun Nut
Rodslinger's Avatar
Quoted: 134 Post(s)
TTT since the spam filter keeps catching Rosco in this thread for some reason.
post #10 of 17 Old 11-07-2013, 06:22 AM Thread Starter
Rodeslinger, what does TTT mean, and should I start a new tread becouse of the " spam filter "?
Rosco69 is offline
