Noob question: oil in the valley ! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-30-2013, 04:47 PM Thread Starter
So I have a real nasty oil leak. Drips a good puddle when driving and for a few minutes after I shut it off. I pulled the trans inspection cover and the rear main or pan, they look dry. Looks like its running down the starter and then out the vent of the inspection. Upon further investigation it looks like there is puddles of oil in the valley of the block and then running out the hole on the passenger side. So the question is what's leaking??
What are the usual suspects to check to see if they are leaking and if someone can hook up a link on how to check or disassemble parts to check that would be awesome
Some Drunk Guy is offline
post #2 of 4 Old 10-30-2013, 04:49 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
Probably the high pressure oil pump.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 4 Old 10-30-2013, 05:40 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Clean it first. Really good.
High pressure oil pump and associated orings leak really fast.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 4 Old 10-30-2013, 06:22 PM Thread Starter
Sorry noob question, is the high pressure oil pump on the front of the engine?
