HPOP Issues? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-30-2013, 02:42 PM Thread Starter
HPOP Issues?
I posted last week about my PS pump being loud and noisy (knocking and bearings) grinding. Well after that replacement, tensioner assembly and pulley I pulled the belt to see if I was chasing a ghost...and I was... The knock comes on when she reached operating temp and then it sounds like marbles in the sink disposal. Only at idle and on deceleration does not make noise under power. All fluids check out nothing else out of the ordinary. I was told on here HPOP or cam gear....how do I confirm, pumps are not real cheap. Thanks in advance guys
Az SON is offline
post #2 of 2 Old 11-02-2013, 06:54 PM
Do not continue to drive the truck. If the HPOP is in the process of blowing it could be contaminating the oil and you could ruin your injectors and possibly much more.
Hook a scanner up and test for codes
'95 ECLB XLT 4x4, E4OD, K.P. D60, 4:10's, 221k, TW custom tunes, 1st Gen Lightning 40/20/40 seats, Wicked Wheel 2, Bar None Bellowed Up-pipes, 360* thrust bearing, Garret Deleted Pedestal + H.F. Outlet, 6.0 fan, CCV dump, Melling LPOP, HPX S.S. oil line, Stancor GPR, 203* T-Stat, MBRP 3" D.P. to 4" exhaust, Tymar Intake, IssproEV2 gauges, Aeroforce Interceptor, Adrian Steel Box, Lund Screen-Front, Donaldson Air & Oil Filters, 2nd Owner
AccordinToJordan is offline
