Noob question HPOP how to check ? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-29-2013, 08:26 PM Thread Starter
Can anyone tell me where to check the oil level of the HPOP?
My truck has a hard time starting when it's cold first thing in the morning. GPR checks out. I have not tested the gp connections yet, but I have a pretty good oil leak at the back of the block and I'm wondering if I should check the HPOP to ake sure it's not draining
Some Drunk Guy is offline
post #2 of 17 Old 10-29-2013, 08:34 PM
What engine and year?
97 F350 7.3 super cab full bed dually
Autometer Sport Comp II boost and egt
TS 6pos tuner
Clutch clevis mod
Tymar intake
Stancor/White & Rogers GPR
Dyno test 221.5hp @ 187,000 mi. Before mods.
Other mods soon :
diamond back dp and 4in exh
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #3 of 17 Old 10-29-2013, 08:53 PM Thread Starter
I have a 96 7.3
post #4 of 17 Old 10-29-2013, 08:59 PM
Hpop is located in the front of the engine. On the drivers side. There is a flat top with a screw in it. That is where you can access the fluid level. It is normally not needed since the oil in there kind of flows to the injectors as it is used to fire the injectors then it is recycled.
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #5 of 17 Old 10-29-2013, 09:02 PM Thread Starter
So how do you check the oil level? Do you have to remove the screw?
post #6 of 17 Old 10-29-2013, 09:03 PM
On my 97 when cool weather gets here I make sure the batteries are in tip top condition and a fresh oil change. Seems to help with cold starts. You also may want to plug the 110v block heater in at night. You can also cycle the glow plugs several times. They are still on even when the "wait" light goes out for about 2 or 3 minutes.
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #7 of 17 Old 10-29-2013, 09:05 PM
You remove the screw and stick a small something like a broom straw in. But.... If it's been running it does have enough in it. If it's leaking it would not work correctly when the engine is running.
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #8 of 17 Old 10-29-2013, 09:07 PM Thread Starter
Yeah until I figure out the cold hard starts I've been using the block heater in the mornings. And it's not too cold here but it does get to freezing at night. 36-32 degrees
post #9 of 17 Old 10-29-2013, 09:09 PM
Where u at?
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #10 of 17 Old 10-29-2013, 09:16 PM
Also the GPR upgrade to the Stancor might help even with good test results since they pass current to do the heat job the volt test may be misleading.
TS 6pos tuner
Clutch clevis mod
Tymar intake
Other mods soon :
ebp del ped
ccv mod
ww2.
drsmith3 is offline
