97 powerstroke cali model HELP!!!!! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-28-2013, 07:01 PM Thread Starter
ok i bought a 1997 powerstroke cheap guy was told the engine was toast by a shop because of excessive blowby which was do to a glow plug that blew the guts out of it fixed that and found some other issues
so here is what i know and what i have it is a cali model with code ab injectors two of which are not deflecting oil out of the spouts so i bought a set of used code aa injectors not knowing i had code ab injectors is there any reason i cant mix and match? im assuming thats not possible but is there any reason my truck wont run on the single shots when i have split shots?
any help would be greatly appreciated im stuck!!!!!!!!!!!!
dieselkidd is offline
post #2 of 8 Old 10-29-2013, 08:05 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
Will it run? Yes.
Will it be happy? No.
The injectors are different fuel volumes. On acceleration the mismatched injectors will be contributing differently to the system causing "misses". Also, the double pump of the injectors is most noticeable at idle. The AAs not designed to be fired twice in a row make a gnarly sounding engine.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 8 Old 10-29-2013, 02:22 PM
sgt dave's Avatar
Quoted: 3 Post(s)
you will need custom tuning to run the aa's in your truck.
i have a 96 cali model that i upgraded to ac codes. i had tony wildman do my tuning and have been running it for 4 years and no problems.
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #4 of 8 Old 10-31-2013, 09:46 PM Thread Starter
well it shook bad with the stock splits in it i swapped out to the singles and fired it up tuner free and a little shake i installed my superchip tuner and no shake at all im gonna drive it day after tomorrow see how she runs and work some of the air out thanks for the help
post #5 of 8 Old 11-01-2013, 07:44 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
If you can get a Federal PCM (about $100 and something in the NAW4-6 range) and re-pin the harness connector your truck will become very tune-able. Singles are more reliable and that splits PCM can fetch you $800-1000 to someone that is trying to keep a stock truck going.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #6 of 8 Old 11-01-2013, 07:23 PM Thread Starter
well my dad installed a tuner for the wrong year when i first got my truck and it wiped my pcm clean i got a replacement one from autozone for about 120 did i put a federal one in it?? i have had no weird lights on everything works normal
post #7 of 8 Old 11-01-2013, 07:42 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
The two PCMs are not interchangeable. The wires are in different places. Near the connector is a printed sticker. There are three letters and a number. What does yours say? Example, my old Cali PCM was a MME2.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #8 of 8 Old 11-01-2013, 09:06 PM Thread Starter
well if they are not interchangeable i mush have got the right one haha but all i know is it was 100% better with the singles put in at an idle i still need to drive it though ill try with and without tuner
