Fuel Pump leaking? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-27-2013, 04:36 AM Thread Starter
rockinthe4banger's Avatar
Fuel Pump leaking?
I am a Neebie to the org but have been a long time PSD owner. I have always had a little leak in the valley but cured it with the banjo nut washers. Now I have a rather large leak and a rough idle at times. There is a large puddle at the back of the valley (under fuel pump and turbo). The rough idle disappears when I step on the go pedal but returns when the idle returns to normal. I purchased the fuel bowl o-ring rebuild kit from Diesel O-Ring and plan on replacing all the o-rings in the bowl, regulator, and pump. During research, I discovered there is two weep holes on the bottom fuel pump. Could the rough idle and large fuel leak be the caused by the fuel pump going bad and leaking out the buttom? Any and all help would be appreciated.
Thanks
FNG (F&%# New Guy)
rockinthe4banger is offline
post #2 of 7 Old 10-29-2013, 07:48 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Yes, the "lower" pump is the high pressure pump to the injectors. The leak could be letting air in or too much pressure out to fire the injectors correctly. Time for E-fuel...
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 7 Old 10-30-2013, 03:54 AM Thread Starter
I changed the fuel pump and rebuilt the fuel bowl NO LEAKS!!!!!!!!! But I still have the rough idle.
post #4 of 7 Old 11-02-2013, 09:02 AM
fuel leak
I have a fuel leak also
Where did u buy the pump from?
Also where i can buy a o rings kit for the fuel bowl and pump
fedeavakian is offline
post #5 of 7 Old 11-02-2013, 09:14 AM
Arcturus's Avatar
1994-1998 Ford 7.3L
and some how to's
Instruction Sheets and Information
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #6 of 7 Old 11-02-2013, 11:58 AM
thanks
Thanks arcturus
post #7 of 7 Old 11-03-2013, 04:23 PM Thread Starter
I bought the fuel pump from Auto Zone $90.00. I bought the O-Rings from Guzzles Diesel O-Ring.
