first post....wont start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-26-2013, 06:51 AM Thread Starter
I have been lurking here for a month reading about these trucks since I purchased mine last month. 1996 f350 Dually with a 5 speed. Mine ran rough when cold like a few cylinders were not firing but after it warmed up a few minutes it was fine. I usually let it warm up a few minutes before I drive it. I was late the other morning, fired it up and took off. It was running really rough and then it died. It was pretty cold....around 35 degrees. Made it 1 mile down the road. I drug it back home and have been trying to get it to start. I changed the cps. I also tried starting fluid to get it to fire but nothing. I went and borrowed my brothers scanner and did the buzz test. All sound fine but #8 is a little lower. From my reading that seem to be common. I do have smoke coming out of the pipe when I try to start it. It will not even try to fire. It is not throwing any codes......Did I damage the engine somehow? Any advice? I am new to diesels and do not know what to look for. I have read through a bunch of diagnostic threads and it looks like everything is functioning correctly in the scanner.
buggy5872 is offline
post #2 of 6 Old 10-26-2013, 07:09 AM
Quoted: 60 Post(s)
Did you try switching tanks? How much fuel in whichever tank you were running on?
madpogue is online now
post #3 of 6 Old 10-26-2013, 07:15 AM Thread Starter
rear tank is messed up. front tank I filled up the day before this happened. I even changed the fuel filter yesterday. fuel filter housing was full and re-filled after I put in the new filter. My brother said it should fire on starting fluid even if it does not stay running. It does not even try to fire.
post #4 of 6 Old 10-26-2013, 08:10 AM
Quoted: 60 Post(s)
What brand of CPS did you install? Does the tach move when you crank it?
post #5 of 6 Old 10-26-2013, 10:38 AM Thread Starter
I bought 2 from ford....tried them both...tach moves
post #6 of 6 Old 10-26-2013, 02:11 PM Thread Starter
Just tested fuel pressure and it is 55 psi while cranking.
