Glow plug resistance - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-21-2013, 05:39 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I ohm tested my GPs yesterday and i got some interesting results. Im getting ~2.2 for all of them except GP #6 im getting ~1.8. What do those numbers mean? I thought they were supposed to be all at ~1.0 ohms. It doesnt seem likely that they all are going bad at the exact same rate at the exact same time other than cylinder 6 or could i have used the multimeter wrong?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 7 Old 10-21-2013, 06:34 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Do you "zero" the meter by shorting the leads before taking measurements? Also are you using the correct scale for the expected resistance? Cheers!
Patrick Feeley is offline
post #3 of 7 Old 10-22-2013, 04:57 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Yes i touched the leads together and it would read then when they were separate it showed infinite. As for scale i used the 200 ohm(lowest) is that right?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 7 Old 10-22-2013, 05:15 PM
Quoted: 15 Post(s)
Sounds like you are correctly measuring. It does seem odd though. I know my "cheap" multimeter will not zero even with leads shorted (it will read about 1.2 ohms, where my Fluke will. How many miles are on your GPs? Cheers!
post #5 of 7 Old 10-23-2013, 05:21 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Well i talked to the electric guy at work and he said you gotta subtract the ohms that the leads read touched together from the reading you get from testing so when i do that i get .9 ohms so well in spec but the 1.8 on cylinder 6 is .5 so that one may need replaced some time in the near future.
As for miles i havent the slightest truck has between 190000-250000 miles(odometer replaced by POs PO so how reliable that is is relative) so it honestly could still be the same ones from factory because the VCs look pretty undisturbed.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 7 Old 03-11-2017, 11:31 AM
Quoted: 2 Post(s)
When you ohm these glow plugs, do you go back to the black lead on the battery or across the pins in the UVCH?
2002 Crewcab Shortbed 4x4 Automatic
just passed 200k miles
marcfo is offline
post #7 of 7 Old 03-11-2017, 02:22 PM
Quoted: 53 Post(s)
There are no ground terminals on the UVCHs; the GPs ground through their threads. So yes, put the other meter probe on the battery - or a good ground.
madpogue is offline
The Following User Says Thank You to madpogue For This Useful Post:
marcfo (03-13-2017)
