smoke? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-19-2013, 04:05 PM Thread Starter
smoke?
when fisrt started the truck puffs white smoke out the stack it also does it when i return it to a normal idle after a few seconds of 1000-1100 rpm. any kind of idea on why its doing it. my only guess would be rings. ive not done a whole lot of work on my diesel still trying to get it back on the road
96-Rollin-Red is offline
post #2 of 8 Old 10-19-2013, 04:40 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Could be lack of fuel
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 8 Old 10-19-2013, 09:25 PM Thread Starter
another quick question. when i let the RPM drop from 1000\1100 to idle there is a vibration in the entire drivetrain. it did this before so when i changed my clutch the dual mass flywheel absortion springs between the 2 plates were demolished and was forced to buy a new FW. thats only been 1,500 Miles and it started again. whats could be a possible cause of the springs breaking?? im not aggressinve when i release the clutch and i wouldnt think that floating gears would do it, or would it?
post #4 of 8 Old 10-20-2013, 08:04 AM
Doesn't Even Care
Quoted: 69 Post(s)
Change the flex plate to a single mass. The dual masses are prone to problems
Nick
"The Mistress"
post #5 of 8 Old 10-20-2013, 09:07 AM Thread Starter
will i need to do any other conversions or just bolt it in?
post #6 of 8 Old 10-20-2013, 09:24 PM
Doesn't Even Care
Quoted: 69 Post(s)
No...I don't think so. I think the existing clutch will work fine.
Nick
"The Mistress"
post #7 of 8 Old 10-21-2013, 10:15 AM
If you switch over to a Single Mass Flywheel you will need a new clutch and pressure plate. It all comes as a kit.
williameub is offline
post #8 of 8 Old 10-21-2013, 12:59 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The white smoke on start up is engine not being warm enough, could be glow plugs or the relay
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
