Idles rough, smooth when driving - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-17-2013, 08:04 PM Thread Starter
ArXane's Avatar
On my 95, sitting there ideling. Engine seems to be running rough like a gasser out of time. When I'm out driving it can't feel any roughness and great power.
Here is what I've done:
Replaced #3 injector 100 miles ago
New ucvh
New glow plugs and relay
Cleaned ebp tube
What should be the next test? Would really like to not have to go to town for a scanner.
2000 F250 Lariat, CC, Long Bed PSD, 4x4, Manual, 102K Miles 4.30 gears, Truspeed
Performance Mods: Tuned by PHP, Wicked Wheel, Gauges, AIH Delete, 5" straight exhaust, DIY Intake
Suspension: 8" Fabtech all spring lift, Fabtech Dual Front shock mounts, Fabtech Dual steering stabilizer, 17" ATX Vice, 37" Toyo M/T
1995 RC F350 Longbed 4x4, Manual, 310K miles, Downpipe, cat delete, FPR shim. (Farm Truck)
ArXane is offline
post #2 of 3 Old 10-22-2013, 05:50 PM
rockinthe4banger's Avatar
I got the same issue!!!! Sometimes it idles smooth and then others it idles rough like is gonna stall. If I step on the go pedal it goes away until the rpms drop. I have changed filters and etc... My next venture is to check the screen in the fuel pressure regulator on the fuel bowl, see if that is clogged. Let me me know if you find anything out.
rockinthe4banger is offline
post #3 of 3 Old 10-22-2013, 06:23 PM Thread Starter
ArXane's Avatar
I did my screen. It was very plugged. Helped but still rough ideling.
ArXane is offline
