Stopped to look at a chevy and wouldn't restart - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-17-2013, 07:37 AM Thread Starter
95 F350 5 speed crew cab dulley.
Stopped off and set for 5 min. Went back and cranked but wouldn't start.
30 min later refired and been running ever since. In last 18 months we have replaced fuel filter housing (hole in bottom) all fuel hose with blue hoses from Ford,fuel pump,glow plug relay,water pump all hoses and clamps,P/S and vacumn pumps. I tow 11,k tagalong camper and by far it is the best towing and driving truck I have ever used. Any and all advice will be appreciated.
Thanks
toold11
tooold11 is offline
post #2 of 6 Old 10-17-2013, 07:39 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
That's because it felt betrayed. Lol jp hope you get it figured out.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 6 Old 10-17-2013, 07:50 AM
Arcturus's Avatar
Well that sure sounds like a CPS. Try your spare if you got one. If that's not it, someday it will be and you will have spare.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #4 of 6 Old 10-17-2013, 08:16 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
2nd this. CPS is usually numero uno check for a 7.3 no start, if that doesnt work Diagnosing a 7.3 no start
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 6 Old 10-18-2013, 10:28 AM Thread Starter
tooold11
Replaced cam sensor still no start. Ran check list found bad maxi fuse 17 replaced no start. Truck started to crank slowly tested battery DS pulls down to 3 volt pass side battery showed no load.
unhooked both batteries and loaded individually and both held 11 volts.
Starter replaced 3 wks with O'Reily's lifetime.
tooold11 is offline
post #6 of 6 Old 10-18-2013, 11:36 AM
Quoted: 50 Post(s)
Hard to decipher the above, but -- when you load test each battery separately with a load tester, they show okay? But when you hook 'em up and crank the starter, the driver's side battery voltage drops to 3V? I would say that means the positive crossover cable between the two batteries is shot, or one of the terminal/post connections on the driver's side battery is dirty/bad.
Prolonged proximity to Chevies can do this kind of thing....
madpogue is offline
