Cranks but wont start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-15-2013, 04:39 PM Thread Starter
Unhappy Cranks but wont start
Went out to start my truck one morning it started right up idled for a bout 3 seconds and shut off like someone had turn the key off. Now it wont start at all itll try but wont turn over. my glow plug relay was broken so i thought that might be it i replaced it and it still does the same thing. Almost seems like its not getting any fuel but ive opened up the fuel bowl and theres fuel in there so could it not be moving fuel from the fuel bowl to the engine im completely lost.
96psdmike is offline
post #2 of 6 Old 10-15-2013, 06:13 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Does the Wait-To-Start light come on? Is the CEL illuminated? White smoke out the exhaust when cranking? Check the main oil level. Check the oil level in the High Pressure Oil Pump (HPOP) reservoir. Check the fuel pressure when cranking. Happen o have a spare Cam Position Sensor (CPS) to try? Cheers!
Patrick Feeley is offline
post #3 of 6 Old 10-15-2013, 07:05 PM
We are having the same problem. It will start with starting fluid but will not run and won't start with the key. Fuel in the fuel bowl.
cmhunni is offline
post #4 of 6 Old 10-19-2013, 10:19 AM Thread Starter
Yes the wait to start light comes on. I don't know what the cel light is, and it does not white smoke when trying to crank. I tried unplugging the icp sensor someone said it could work but nothing and the plug looks fine.
post #5 of 6 Old 10-25-2013, 04:05 AM
cel is check engine light.. should be a yellow/orange light on the right side of the dash. have you had any problems prior to it not starting??
97 F350 CCLB Rifraff 6637 intake, 4 inch exhaust, 203 T-stat, Beans electric fuel system, PHP Hydra chip, triple disk converter
turbodieself350 is offline
post #6 of 6 Old 10-25-2013, 06:26 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Check this out it may help, any other questions just ask
Diagnosing a 7.3 no start
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
