96 F350 Replaced the CPS now it sputters - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-14-2013, 06:30 PM Thread Starter
Angry 96 F350 Replaced the CPS now it sputters
Just replaced the CPS because the truck would die and eventually decided not to start at all. After replacing it, she fired right up. Now when I start to drive it and get to around 1500 on the tach, it starts to kinda sputter and knock. Thought it might just be because it was cold, but it still does it warm too. seems to idle fine. I do have a fuel leak from the pump non top of the engine I believe, but that shouldn't cause this issue.
TexasRanchStrokin is offline
post #2 of 10 Old 10-14-2013, 07:53 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Where did you get the replacement CPS? If from aftermarket, there have been issues with some being bad out of the box. Cheers!
Patrick Feeley is offline
post #3 of 10 Old 10-14-2013, 11:07 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
delphi and borg warner make the best aftermarket cps.
i have tried both and can verify it is a huge improvement in idle quality and power over the ford cps.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #4 of 10 Old 10-15-2013, 04:38 AM Thread Starter
I picked the CPS up from Napa. I read in another forum to stay away from the BW CPS and just go with the Ford CPS. So confused! Hate doing a job over again!! Seems like this is just a Hall effect sensor. How do you mess up something so simple?? Where can I pick up a delphi?
post #5 of 10 Old 10-15-2013, 04:45 AM Thread Starter
I also read that you need to disconnect the battery when you replace the CPS so the computer re-learns the new CPS? Is that true?
post #6 of 10 Old 10-15-2013, 08:59 AM
Quoted: 48 Post(s)
"Best aftermarket CPS" == "Sucks least". Just get one from the Ford or International dealer and be done with it.
BWD - Broke While Driving
madpogue is offline
post #7 of 10 Old 10-15-2013, 09:09 AM Thread Starter
Do I get teh blue or grey, or does it matter?
post #8 of 10 Old 10-15-2013, 02:27 PM
PSDprepper's Avatar
I had the same problem with my truck after I replaced my old cps with anew one from napa.. I bought two from napa before I bought one from ford and it fixed the problem
- Tyler
PSDprepper is offline
post #9 of 10 Old 10-16-2013, 05:27 AM Thread Starter
Update... + the next issue
Okay, I replaced the one I bought from NAPA with one from ford (dark blue). Truck runs like a champ again!! Idles better, no sputter or hesitation... Now on to my next issue...When I first start it up, it has a miss, like one of the injectors isn't working. I did unplug the injectors one by one a while back and thought I found a dead injector (passanger side closest to teh fire wall). I replaced it with a known good injector, but never tested it individually again. Problem is, once it's up to operating temp, it smooths out and no more miss...Kinda stumpped on this one. Anybody have this issue?
post #10 of 10 Old 10-16-2013, 06:20 AM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
'95 miss when cold, fine when warm
look at this thread.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
