Multiple DTC. Where to start? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 10-12-2013, 06:09 PM Thread Starter
Alrighty...
When driving, very seldom, I will get a CEL, throttle wont respond. The engine stays running at idle with no missing. A few seconds later, CEL goes away, and the throttle comes back. Everybodys happy again.
So, I pulled a couple codes today.
P0221 | Throttle switch B circuit performance | Failed pedal assembly
P0236 | Turbo boost sensor A circuit performance |Restricted inlet/exhaust/supply hose, missing hose
P0470 | Exhaust back pressure sensor circuit malfunction | Biased sensor, open signal return
P0603 | Internal control module KAM error | Open PCM pin, disconnect B+, faulty PCM
P1211 | ICP pressure above/below desired | IPR valve failed, stuck, or shorted to ground
P1705 | TR sensor out of self-test range | Operator error, circuit failure, faulty sensor, PCM
P0221 | Would explain the CEL and no Throttle.
P0236 | All Turbo hoses are intact and in good condition. ???
P0470 | Bad Sensor?
P0603 | Bad pin on PCM?
P01211 | ICP is Bad maybe?
P01705 | This would explain the terrible lope I had on startup for a while.
My scan tool wouldnt clear the codes so Ill have to wait till Monday before I can get my hands on something that can.
Thanks guys!
williameub is offline
