'95 miss when cold, fine when warm - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-12-2013, 01:24 PM Thread Starter
Hi: My 95 has a miss when cold but when fully warmed up (20 mins?) runs fine? Any suggestions? Thanks, Larry
lconn is offline
post #2 of 8 Old 10-15-2013, 12:21 PM
Jameson Bearden's Avatar
Mine does the exact same thing. Been doing it for 2 years. I have another thread on that subject. Still trying to figure out what is causing it.
1995 F250 ECLB ZF5 4X4:
3" DP to 4" Exhaust
Tymar Intake
CCV Mod
Valair Clutch
Gauges
Jameson Bearden is offline
post #3 of 8 Old 10-16-2013, 05:45 AM
I too have the same problem! Also posted in anothr thread for help!! I'm going to try and do some troubleshooting this weekend if I get a chance. I'll let you know what I find.
TexasRanchStrokin is offline
post #4 of 8 Old 10-16-2013, 06:06 AM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 4 Post(s)
stiction, sticking injectors . search seafoam injector cleaning on this site and powerstroke nation , can't remember which site I read it. This is only a temp. fix .If you have over 100k on the injectors, its time for a rebuild.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #5 of 8 Old 10-16-2013, 09:42 AM
any idea what an injector rebuild costs? Better to send in one at a time or all at once?
post #6 of 8 Old 10-16-2013, 10:56 AM
Ford7three's Avatar
You can try running and additive like Rev-X to help with oil stictation ect. But it will still only mask an injector problem.
Ford7three is offline
post #7 of 8 Old 10-16-2013, 10:58 AM
Ford7three's Avatar
If you can, get a full set of remans all at once, they will come with a warranty and youll have a full set there ready to swap at once.
post #8 of 8 Old 10-16-2013, 11:01 AM
Are there rebuild kits out there that are any good? If I wanted to go to higher flow nozzles, would that kill MPG? Would I need to do anything else for higher flow nozzles? If I decide to send them in, where should I send them?
