fuel fuel fuel - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-10-2013, 07:46 PM Thread Starter
fuel fuel fuel
Just installed a new fuel pump and lines and I rebuilt the fuel bowl. Now my fuel filter light comes on from time to time. I filled the fuel bowl with tranny fluid after the rebuilt would that turn on my fuel filter light? Also what am I supposed to check when that light comes on?
Just for aside,
My E-brake light also comes on at random and kills my cruise control. What would be the best place to start poking around?
GreMonte is offline
post #2 of 3 Old 10-11-2013, 10:26 AM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
Maybe it didn't like the more viscous tranny fluid if it was straight ATF? It usually means there is a folter restriction. Have you tried a different filter?
The e-brake light will come on due to:
1) The e-brake switch on the pedal assembly closing (or the wire grounding for some reason)
2) Low brake fluid level
3) Low vacuum (so check for vacuum leaks or even put a gauge on the system to if the vacuum level drops. You should get 17-24" Hg at idle).
Cheers!
Patrick Feeley is offline
post #3 of 3 Old 10-13-2013, 12:41 PM Thread Starter
Cheers!
Right on the money!! After a few days I no longer see the fuel filter light so I think it ran all the tranny fluid out, Also it was the e brake switch that was bad.
GreMonte is offline
