help needed for engine missing - Ford Powerstroke Diesel Forum
post #1 of 1 Old 10-10-2013, 01:43 PM Thread Starter
About 2 weeks ago I cleaned the ebp tube and sensor. the tube was clogged solid. now I've been feeling it seem to miss slightly. slightly rough at idle and while cruising. in park and revving to motor it shakes bad like a bad miss. I pulled these codes help needed for engine missing-imageuploadedbyag-free1381441291.822509.jpghelp needed for engine missing-imageuploadedbyag-free1381441301.239269.jpg
also watching the psi reading from the sensor at idle was about 15psi and while revving the motor about 18/19psi. the exhaust valve fault is from my ebpv being unglugged. the truck runs fine otherwise, no loss of power, and no smoke.
could it be a bad ebp sensor?
tony0713 is offline
