Oring fell into oil passage - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-10-2013, 11:58 AM Thread Starter
whiteout94's Avatar
So I pulled the turbo to replace the orings on the pedestal and the small one on the block side fell into the larger port in the block, im guessing oil passage for the turbo. So did I screw myself here or does it just go back to the pan? Here's a pic I tried to snap down the hole to see if I could see it
1994.5 F350, 4x2, CCLB, ZF5 South Bend Clutch, Diamond Eyes 3" DP-5" Straight Pipe, DIY 6637 intake, ISSPRO EV2 Gauges, 08 Rear Diff Cover, DieselSite Coolant Filter, EBPV and pedestal delete, Riffraff HPx, DIY EFuel, 7.3 SD intercooler
1994.5 F250, 4x2, ECLB, 189k, 5 speed, SOLD
whiteout94 is offline
post #2 of 2 Old 10-11-2013, 11:28 AM
Fummins90's Avatar
It should just go into the pan and will come out with an oil change.
-Jacob
PowerHungryPerformance --
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Fummins90 is offline
