Missing Low Power/UVCH - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-01-2013, 06:18 PM Thread Starter
ArXane's Avatar
On my 95, It developed what sounds like a miss and very low power. On the 1/3 UVCH plug it has a burnt plug/wire for Glow Plug 1. I removed the valve cover and everything looks normal. While its running, if I unplug the 1/3 plug, the sound of the engine doesnt change.
I will pick up up a new UVCH/gasket tomorrow, Anything else or any other ideas?
2000 F250 Lariat, CC, Long Bed PSD, 4x4, Manual, 102K Miles 4.30 gears, Truspeed
Performance Mods: Tuned by PHP, Wicked Wheel, Gauges, AIH Delete, 5" straight exhaust, DIY Intake
Suspension: 8" Fabtech all spring lift, Fabtech Dual Front shock mounts, Fabtech Dual steering stabilizer, 17" ATX Vice, 37" Toyo M/T
1995 RC F350 Longbed 4x4, Manual, 310K miles, Downpipe, cat delete, FPR shim. (Farm Truck)
ArXane is offline
post #2 of 3 Old 10-01-2013, 07:30 PM
If you have the valve cover of anyway, you could unclip each injector one at a time and see if it made any difference. Chances are if you have a burned glow plug wire, you probably have under valve cover wiring harness issues you can't see. An old trick I learned from gassers check your wiring on a dark night with no lights and your engine running. If you have wiring issues you can usually tell.
gfaststroker is offline
post #3 of 3 Old 10-01-2013, 07:44 PM Thread Starter
ArXane's Avatar
Good idea about night... except its to cold outside now :-) Ill try unplugging each injector in the morning. Thank you.
ArXane is offline
