unhooked wire?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-30-2013, 01:13 PM Thread Starter
unhooked wire??
while i was looking at my engine today i noticed this wire that wasn't plugged into anything. Is this supposed to be like that? What is it? where does it go?Unplugged wire in 7.3 Powerstroke - YouTube
powerstroke814 is offline
post #2 of 6 Old 09-30-2013, 01:22 PM
JSchuricht's Avatar
Looks like one of the wires to the fuel bowl.
JSchuricht is offline
post #3 of 6 Old 09-30-2013, 01:31 PM Thread Starter
Is it hurting anything the way it is? truck runs fine just noticed the wire that was sitting there
post #4 of 6 Old 09-30-2013, 01:43 PM
Arcturus's Avatar
Probably either the fuel bowl heater or the water in fuel sensor. It's up to you whether you need them or not. I don't live where it gets very cold so I don't have my heater hooked up and I just use the fuel bowl drain valve every so often to drain water out.
Neither one of mine are hooked up.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #5 of 6 Old 09-30-2013, 05:46 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
That looks like the wire for the fuel restriction sensor. You don't say what year the truck is, but on a 94-95 it would connect on the sensor on the back of the fuel bowl towards the bottom. On a 96-97, the sensor would be on the fuel pressure regulator block (driver's side of the fuel bowl). Cheers!
Patrick Feeley is offline
post #6 of 6 Old 11-10-2013, 07:27 PM
sputnik801's Avatar
Quoted: 3 Post(s)
My fuel heater wire looks exactly like that. Mine was disconnected for a while when the heater was broken........Might be that.
sputnik801 is offline
