E-Fuel Conversion, Fuel Pressure Drops - Ford Powerstroke Diesel Forum
post #1 of 21 Old 09-30-2013, 06:53 AM Thread Starter
OneBadV8's Avatar
So, I spent the weekend converting my 7.3 to electronic fuel using mostly 2001 parts. I pretty much used this thread as my guide http://www.powerstroke.org/forum/7-3...bs-trucks.html
Now, when I turn the key to the on Position it holds constant pressure at 70 PSI, but as soon as I actually start the motor you can watch the fuel pressure gauge just start dropping until it hits zero. The truck stays running though and doesn't seem to idle any different.
Any ideas on where to start? I'm lost. There are no leaks, I've checked every fitting from the tank to the regulator.
OneBadV8 is offline
post #2 of 21 Old 09-30-2013, 08:27 AM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
First thing I would do is try a different gauge
Trucks and parts............
kanuck15 is offline
post #3 of 21 Old 09-30-2013, 08:35 AM Thread Starter
OneBadV8's Avatar
It seems change as when I update the regulator when the key is in the on position but without the motor running. It's only when I start the motor. The gauge doesn't change if it stays on with the motor off.
I do have another gauge though, so I'll swap those just to be sure.
OneBadV8 is offline
post #4 of 21 Old 09-30-2013, 10:13 AM Thread Starter
OneBadV8's Avatar
Could this just be a ton of air in the lines? If so, how long would that take to work through? I know all the lines were completely drained by the time all the new stuff was hooked up.
OneBadV8 is offline
post #5 of 21 Old 09-30-2013, 10:20 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Not likely if you just leave the key on engine off it will clear 99% of the air out itself. And plus the truck wont even start if there is any significant amount of air in the lines.
Like kanuck15 said try a new gauge first before anything else but still seems like a strange occurrence for a bad gauge. How do you have the fuel pump wired up?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 21 Old 09-30-2013, 10:22 AM Thread Starter
OneBadV8's Avatar
Fuel pump is wired the same way that mjonesjr wired it up.
OneBadV8 is offline
post #7 of 21 Old 09-30-2013, 10:38 AM
Chapter Director
Quoted: 5 Post(s)
Ok that seems alright.
Have you actually drove the truck with the gauge reading 0 psi or are you just watching it at idle? Honestly if the truck is running just fine but yet still reading 0 psi then it has to be the gauge itself strangely.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 21 Old 09-30-2013, 10:49 AM Thread Starter
OneBadV8's Avatar
Not yet, its just been idling. I didn't want to take it out and possibly get stranded because of it. I do have a second gauge I just assumed it was a good reading since it adjusts with the regulator and gives good readings while just having the key on.
OneBadV8 is offline
post #9 of 21 Old 09-30-2013, 10:55 AM
Chapter Director
Quoted: 5 Post(s)
Yea i understand, just seems strange it runs just fine. Try revving it up at idle and see if it kinda chokes for fuel. The only explanation i can think of is if the fuel pump is just strong enough to pressurize the fuel system but as soon as the injectors start sucking the fuel it drops its down to an unmeasurable pressure?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 21 Old 09-30-2013, 11:25 AM Thread Starter
OneBadV8's Avatar
And that's possible too. I'll look into giving it gas and seeing if it chokes or not this evening.
The Fuel Pump was out of an '01 E350 van. That's probably the only part that wasn't bought new, but I can always get a new pump if I have to. Trying to exhaust any other options first though.
Thanks for the suggestions so far!
OneBadV8 is offline
