Hpop resivour leaking down - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-30-2013, 04:48 AM Thread Starter
southchitownstrokin's Avatar
About 2 weeks ago my truck sat for a week while I was on vacation.
When I got back it took a few try's to start it, which is unusual for my truck.
Drove it around for a few days no problems. Go out one morning to start it and it won't start. Ended up figuring out the hpop oil resivour leaked down. So I filled it up and she fired right up. At the same time I changed the fuel filter thinking that it wouldn't hurt anything.
Drive it around a few days again, it's great! Starts up quick with the new filter, it's running great, no problems.
Go out to leave for work this morning and it just cranks.,..and cranks, and cranks some more....
Now I'm assuming the resivour leaked down again, but have not verified this yet, as I am on my way to work now...
What could be causing it to leak back down? I
Think I read injector o-rings somewhere?
I will verify the problem tonight and update if its something else.
Thank you in advance
southchitownstrokin is offline
post #2 of 5 Old 09-30-2013, 10:54 AM
Arcturus's Avatar
Check the oil level at the dipstick while you are at it.
What does your stock oil pressure gauge read? I know that gauge is more of an idiot light but it registers lpop and that is what is in your reservoir but it won't do anything till the engine is running.
If your oil is low in the crankcase then it may be injector orings
When you replaced the fuel filter, was it black or had black in the pleats? That is another indicator that it might be injector oring(s) as well. If it had black in it before you changed it, check it again now that you put some more miles on.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #3 of 5 Old 09-30-2013, 11:26 AM Thread Starter
Stock gauge reads right in the middle where it always has... I do have a small oil leak on this truck, and it blows a lot of oil smoke through the crankcase vent (vented to atmosphere) so I'm adding oil to it every few weeks... Right now it reads in the middle off the hash marks.it does seem to use a little more then it should even with the 2 things I mentioned...
The fuel filter was black.... Ill pull the new one out tonight and check it out
post #4 of 5 Old 09-30-2013, 04:22 PM Thread Starter
Oil pressure gauge reads good.. Right about in the center.
The truck does have a oil leak and blows oil smoke out of the crankcase vent... It does seem to use more oil then it should but I figured it was just blowing out the ccv..
The old fuel filter was black... I can pull the new one tonight and take a look at it
And I will post results
post #5 of 5 Old 10-12-2013, 01:17 PM
Hi: Have same problem, but oil drains back into crankcase. No apparent leaks or burning. ''95 F250 any suggestions?
lconn is offline
