96 7.3 f250 not right - Ford Powerstroke Diesel Forum
post #1 of 23 Old 09-29-2013, 02:58 PM Thread Starter
quicknick106z's Avatar
Angry 96 7.3 f250 not right
So ill start out by how it never starts inless its pluged in and with my chip when i floor it wont spool up like falls on its face like its in 2gear all stock but exhaust and chip dont run the hell out of it but when i do mash it its a turd. But on the 1999 f350 it hauls ***. Please help
96 ford f250 7.3 edge evo straight pipe (Blown up Junk
quicknick106z is offline
post #2 of 23 Old 09-29-2013, 04:02 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
sounds like the injectors are needing replaced
Trucks and parts............
kanuck15 is offline
post #3 of 23 Old 09-29-2013, 06:17 PM Thread Starter
Question
probably. also my father ran vegie oil in it awhile ago. isnt there alittle screen some were in the fuel system? probably cloged
post #4 of 23 Old 09-29-2013, 06:18 PM
kanuck15's Avatar
Quoted: 10 Post(s)
yes on the fuel pressure regulator on the side of the fuel bowl
kanuck15 is offline
post #5 of 23 Old 09-29-2013, 06:29 PM Thread Starter
thank you! i will look
post #6 of 23 Old 09-29-2013, 06:35 PM Thread Starter
what should i be looking for? what do i have to take apart to find it
post #7 of 23 Old 09-29-2013, 06:42 PM
kanuck15's Avatar
Quoted: 10 Post(s)
as you are looking at the fuel bowl on the right side there is a part where the two return lines go into. its held on the bowl by two 10mm bolts. pop that off and you will see the screen on the side. Also on the regulator there will be a black plastic canister. Unscrew it and clean that screen while you are there
kanuck15 is offline
post #8 of 23 Old 09-29-2013, 06:48 PM Thread Starter
most of the time are these cloged up?, what about starting why does it not start when its 90 out?
post #9 of 23 Old 09-29-2013, 06:51 PM
kanuck15's Avatar
Quoted: 10 Post(s)
Have you checked your glow plug system?? it shouldnt need them but it does help
does it smoke at all when its trying to start??
kanuck15 is offline
post #10 of 23 Old 09-30-2013, 11:55 AM Thread Starter
smoke's like crazy!. it has had them done from ford back around 150.000 miles
