Glow plugs gone - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-29-2013, 02:42 PM Thread Starter
7.3powerstroker's Avatar
Glow plugs gone
So I just replaced the glow plugs in my truck about a month ago along with the relay and valve over gaskets and wiring harness's. Started awesome and now it's back to the same no start. I didn't use ford plugs or relay. Then I was told you should so I put a ford relay in and it still doesn't work. None of the harness's are melted everything seems fine. Is it possible that the plugs went that fast ? The brand of plug I used were autolites.
I'm thinking I'll just go get some ford plugs and replace them again.
Sent from AutoGuide.com App
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
3.5"dp to 5" straight pipe
99 Turbo and Spyder
6" Lift
37" BFG KM2's
Harley Davidson Leather buckets
Grant Steering Wheel
Autometer Gauges Pryo,Boost
CB Radio
Custom Bumper(built it myself)
Clear Headlights (black background)
Black Grille and Headlight Trim
Soon to come
Custom Rear Bumper
Headache Rack
6.0l intercooler (already have one just need to pipe it)
rosewood stage 1's
custom tunes
7.3powerstroker is offline
post #2 of 4 Old 09-29-2013, 07:20 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
Measure the voltage drop across the relay's large terminals when the plugs are active. You should get no more than a 0.3V drop. I would get rid of the Autolites as soon as you can otherwise you most likely will have issues removing them later. Cheers!
Patrick Feeley is offline
post #3 of 4 Old 09-29-2013, 08:50 PM Thread Starter
Okayy will do. And why will I have issues removing them later ?
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
99 Turbo and Spyder
6" Lift
37" BFG KM2's
CB Radio
Soon to come
Custom Rear Bumper
Headache Rack
rosewood stage 1's
custom tunes
post #4 of 4 Old 09-30-2013, 11:38 AM
Quoted: 8 Post(s)
It is well known (at least in PSD circles) that the Autolites like to swell and break off when trying to remove them. Cheers!
