Fuel Leak but Cant Figure Out From What.... - Ford Powerstroke Diesel Forum
post #1 of 23 Old 09-25-2013, 10:57 AM Thread Starter
SkinnerBack's Avatar
Where the Y tube bolts to the head & the turbo....... where it bolts to the head on the driver side I have fuel coming up from where it bolts together....... im eventually gonna tear it apart but just wantin a heads up to what I may be gettin into....... thanks in advance.... I can take pics & post some if that will help just let me know......btw its a 96 if it makes a differnce
SkinnerBack is offline
post #2 of 23 Old 09-25-2013, 11:12 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Do you actually SEE the fuel leaking back there or are you just assuming because you see it running down the back of the engine? I ask because the valley of the engine drains back there so the fuel leak can be coming from anywhere on top of the engine and it will collect in the valley and drain down the back passenger side of the engine.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 23 Old 09-25-2013, 11:21 AM Thread Starter
Yes you actually see it, once the engine is off I let it clear off then crank it up it will push alittle bubble out the fuel will gather there, theres a line of silicone that it gathers on & you can see it build up more & more as it runs.....
post #4 of 23 Old 09-25-2013, 11:24 AM
Chapter Director
Quoted: 5 Post(s)
Well the only place that far back would be either the fuel pump hoses or the ports on the back of the head
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 23 Old 09-25-2013, 11:28 AM Thread Starter
No no no...... this is ontop of the motor....
post #6 of 23 Old 09-25-2013, 11:34 AM
Chapter Director
Quoted: 5 Post(s)
Wait, what truck do you have because based on your avatar i think you must have posted in the wrong section.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 23 Old 09-25-2013, 11:35 AM Thread Starter
My avatar is my old truck I just havent changed it
post #8 of 23 Old 09-25-2013, 11:39 AM
Chapter Director
Quoted: 5 Post(s)
Oh ok i did miss the last part where you clarified the year sorry but could you clarify where the leak is because im picturing underneath the turbo. I dont know what you mean by y-tube bolts on the head
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 23 Old 09-25-2013, 11:42 AM Thread Starter
Ok the y piece that comes off the turbo then spits to each head...... it have building up there..... I took a picture of it but cant figure out how to upload it from my phone
post #10 of 23 Old 09-25-2013, 11:46 AM Thread Starter
fuel leak
Maybe you can see it now???
