95 350 No start/no crank. Help please - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-21-2013, 10:13 AM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
installed a chip on a 95 5 speed truck today. truck fired up once chip was in and ran fine, through all settings.
we talked about some things(me and the guy who owns the truck) for about an hour or so. when he went to leave, the WTS light comes on, but theres NO power to the solenoid on the fender to actuate the starter. GP relay comes on, but when you turn the key, nothing. took chip back out, same thing...NOTHING
We tested for power coming to the little wire on the fender solenoid and theres no power to that wire when truck is tried to crank. i jumped out the solenoid and truck fores up, runs perfectly.
I dont know what we could have done to make this not work. After we had it running the first time we shut it off and the only thing that he did was route the flip up to under the steering wheel. is there something im missing? could he have disconnected something on it? tried looking for neutral safety switch and since i have never really looked under the dash of an OBS, let alone another 5/6 speed truck, can someone help?
thanks in advance!
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 10 Old 09-22-2013, 04:47 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
bump??
Sent from AutoGuide.com App
Nick
"The Mistress"
post #3 of 10 Old 09-22-2013, 06:46 PM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
Clutch interlock switch is under the dash on the clutch master cylinder. Cheers!
Patrick Feeley is offline
post #4 of 10 Old 09-22-2013, 06:58 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
could that be the ONLY thing that still allows the WTS light to come on, but will not send voltage to the fender solenoid that kicks in the starter?
Nick
"The Mistress"
post #5 of 10 Old 09-23-2013, 07:48 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
Possibly the ignition switch under the column went bad all good until you turn to start or possibly a broken wire between the switch and solenoid
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #6 of 10 Old 09-23-2013, 08:49 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Did you check the fuses(im sure you probably did) but may have shorted something out accidentally when it got routed into the cab. But the clutch switch is probably the most likely suspect
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #7 of 10 Old 09-23-2013, 03:57 PM
Quoted: 44 Post(s)
WTS light and glow plug relay are controlled by the PCM, as is the engine management itself. Starter circuit is completely independent of it. The chip installation is just coincidental, unless maybe while fussing around under there, you disconnected the clutch switch.
One final test - instead of jumping the two big terminals on the starter relay, remove the connector from the small terminal, and run a jumper between the battery positive and that small terminal. If that cranks the engine, then the relay is good, and the problem is, as suggested above, "upstream" - ignition switch, clutch switch, wiring. If no crank, then the relay is faulty.
madpogue is offline
post #8 of 10 Old 09-23-2013, 05:27 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Yeah, im not getting voltage through that wire that goes on the terminal on top of the solenoid. So I know its upstream somewhere. Thanks for the responses guys!
Nick
"The Mistress"
post #9 of 10 Old 09-23-2013, 07:12 PM
Quoted: 44 Post(s)
You feel any slop in the pedal? When you start it by jumping the relay, did you try driving the truck, and was it hard to shift?
madpogue is offline
post #10 of 10 Old 09-23-2013, 07:54 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
No slop in pedal. Drove fine. I told the guy to check the neutral safety switch
Nick
"The Mistress"
