another 97 obs no start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-20-2013, 09:16 PM Thread Starter
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
hello I am in the process of buying a 97 f250 cc 4wd sb with 298,000 mi from a guy at work it cranks but wont start. I'm a truck driver so I only get about 30 minutes to an hour of time to spend working on it when I do get by the truck. so far I have replaced the cmp (tach bounced now holds steady while cranking) checked all fuses (all good) checked the oil level/condition (good)disconnected the idm shook it to check for sloshing and/or rattling (none found/apparent) checked power to the ipr (12v and .35v respectively) unplugged the icp sensor (no change). I attempted to read the computer with a snap on code reader but it said it couldn't communicate (hmm?)
the next time I get back to it I plan on checking the resistance on the ipr solenoid, check the oil idiot gauge while cranking (forgot what it was doing), check the oil level in the hpop reservoir. if I have time I will check the glow plug condition. I don't have access to any gauges or scan tools at this time (crap) however any ideas are much appreciated
pic of what I'm buying
fordmandan87 is offline
post #2 of 5 Old 09-21-2013, 05:43 AM
How long has it been sitting? Does it crank fast enough (200 rpm) on the tach?
You might check the IDM relay next to the fuse box under the hood, drivers side.
1996 Ford F350 Super Duty XLT Engine Compartment Fuse Box Diagram » Auto Fuse Box Diagram
injun46 is offline
post #3 of 5 Old 09-21-2013, 07:28 AM Thread Starter
Quoted: 3 Post(s)
The truck has sat for 3 months so far however the engine spins free and fast enough to show a needle width above 0 rpm (close as I can figure on tach) I'll check the relays thanks for the box diagrams I was working blind without one so far
update: I just sprung for an auto enginuity scanner with the ford expansion so I get to wait for that to arrive
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
post #4 of 5 Old 09-22-2013, 11:37 AM Thread Starter
Quoted: 3 Post(s)
Ok folks she runs I waited for the wts light to go out sniffed some starting fluid in it and now she runs it was probably the cmp sensor that caused the no start 3 months ago
post #5 of 5 Old 09-23-2013, 02:51 PM
Quoted: 50 Post(s)
Originally Posted by fordmandan87 View Post
I waited for the wts light to go out sniffed some starting fluid in it ....
That was still very chance-y to do. The glow plugs run long after the WTS light goes off. But you dodged that bullet; knock wood, looks like a nice find.
madpogue is offline
