97 7.3L trips checklight, dies then starts ?? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-14-2013, 06:44 PM Thread Starter
Hi, hoping someone here may have ran into this. My 97 will start on occasion and show an engine check light. It will be idling fine then when the light goes off the engine will stumble or more recently completely die. It will then start right up with no check light and run fine. I have replicated this at least 3 or 4 times. I changed the fuel filter, added some Howel's, and changed the cam position sensor to no avail. I have a superchips tuner and run it on performance and also have 4 inch exhaust. Popping 3 codes - p0344, p0221 and p1280. I didn't clear codes after the cam sensor.
Any input would be appreciated,
Thanks,
Chris
Transam1 is offline
post #2 of 9 Old 09-16-2013, 05:53 PM Thread Starter
Anyone ?
Transam1 is offline
post #3 of 9 Old 09-16-2013, 07:42 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
P0221 is for the idle validation switch (two wire switch on the accelerator pedal), so maybe check the wiring and switch operation (switch is open at idle and closes when pedal is pressed just off idle position). The P1280 is ICP out of range low, so check the wiring and connector to the ICP sensor (any oil in the connection?). Cheers!
Patrick Feeley is offline
post #4 of 9 Old 09-16-2013, 08:51 PM
Quoted: 58 Post(s)
What does it do when you set the tuner back to stock and remove it?
madpogue is offline
post #5 of 9 Old 09-18-2013, 11:24 AM Thread Starter
I pulled tune off and cleared codes day before yesterday. Same issue and now popping a code 603 ???
Thanks,
Chris
Transam1 is offline
post #6 of 9 Old 09-18-2013, 12:56 PM
Quoted: 17 Post(s)
P0603 is normal for truck running a chip or tuner (just means power was lost to the PCM, Keep Alive Memory or KAM). Cheers!
post #7 of 9 Old 09-18-2013, 04:04 PM Thread Starter
Thanks, I pulled the plug to the icp and there was oil in it. Shall I surmise that this means it is faulty ?
Thanks in advance
Transam1 is offline
post #8 of 9 Old 09-18-2013, 05:58 PM
Quoted: 17 Post(s)
Yes, it may run with it, but it is leaking internally. Cheers!
post #9 of 9 Old 09-19-2013, 04:16 AM Thread Starter
Thanks Patrick,
I will pick one up today . Their expensive little buggers though.
Chris
Transam1 is offline
